Re: Tranny final ratio, '93 YJ #456873 06/07/04 10:18 PM
GreggieAtTheBat Offline OP
You're right, the main thing I was asking was if it was overdrive, though knowing the true ratio is good too (I do have oversize tires, now I can figure out my true speed -- that is, if I believe my tach...
Anyway, on that pirate site, there's a discrepancy which is probably a typo:
AX5 - 1st gear is listed as 3.93
AX15 - 1st gear is listed as 3.83
since all the other gears are the same, is this a typo (easy to hit 8 instead of 9 or 9 instead of 8) or does the AX5 actually have a lower first gear?
BTW, the other site posted above (from jeeptech) lists 3.93 for AX5 and 3.83 for AX15, also AX15 has a higher rev gear (4.22 instead of 4.74)
1993 YJ S, 2.5L I4, 5spd
30x9.50x15 TAKOs on 15x8 American Racing Rock Crawlers
Re: Tranny final ratio, '93 YJ [Re: GreggieAtTheBat] #456874 06/08/04 01:38 AM
check your pm's... <img src="/forums/images/graemlins/notooth.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5914 MB (Peak: 0.6409 MB) Data Comp: Off Server Time: 2026-11-18 11:53:57 UTC
