Hello all,
I`m new here and I just wanted to introduce myself and my rig. I`m from Northern Ontario Canada and I am a computer geek by day and a wannabe fabricator by night. Nevertheless I`ve managed to do all the modifications to my `88 4Runner myself. (with a little help from friends of course) Among the modifications are a SAS using an `84 axle that I rebuilt myself using a knuckle rebuild kit and Hy-steer crossover steering kit from All-Pro off-road. My springs are 3" Downey units and my hangers are stock Toyota pieces with some minor modifications. Front bumper is an ARB unit housing a Milemarker hydraulic winch and sporting some extra lighting and my hi-lift jack. Rear bumper is homemade using 4" square tubing and mounted on receivers welded to the frame. (I wanted a modular system so I can make myself a huge rack and/or motorcycle carrier in the future)
I always wanted a roof rack but found the prices to be quite prohibitive (especialy from north of the border) so I decided to make it myself. The material cost me all of $50 and the bender cost me $60. At the time I thought this was going to be a steal but after putting some 20 hours into it (including the lights) I now know why they are so expensive!
Anyways, here are some pics. Let me know what you guys think. Also, i`ll be glad to answer any questions you may have.
This is a picture of it way back in `96. It still had IFS back then and it rode on 31" BFGs.
Then in `97 I decided to take care of some minor rusting and a badly degraded tailgate. By then my BFGs were worn and I wanted to upgrade to 33s so I decided to do a body lift. Well everything just snowballed from there and the truck stayed in the garage until this past May long weekend! For most of this time it looked like this.
Finally last year my best friends got some trucks of their own and I decided it was time to get back into 4 wheeling. I got my hands on an `84 front axle and purchased the neccessary hardware to complete my SAS. I had already purchased 33" Bridgestone Dueler MTs (4 years ago!) and had them mounted to some steel 15X10 wheels that I sandblasted and painted black.
I didn`t like the way the front end sat after finishing the SAS so even before testing it, I re-engineered the front hangers to give me more clearance between the spring pack and the sector shaft.
Before
After
Where I had 2.5 inches of clearance, I now have 6.
With this setup I had what I consider "acceptable" flex.
Those pics were snapped the night the truck was going back into the shop to finish the bodywork and paint. My friends and I were planning a trail ride on the Saturday of the May long weekend and this was Thursday night! My friend and I worked until two in the morning to get it to this point
before we quit for the night. Mid afternoon Friday (after work) we finished sanding and preping and finaly sprayed it. That night our buddy flew in from California to spend the weekend so we picked him up at the airport and went out for supper and a few beers while the paint dried. The urethane enamel we sprayed needed 16 hours to fully cure but only 4 hours until it was dry enough to peel the masking so that I could begin reassembling the truck. We stayed up until 3am putting the interior back in and the roof rack on. We ran out of time so the interior trim was put aside and my Bushwacker Cut-out fender flares were not installed either. The next morning I was awake by 7am to try and get the rest of the necessary items taken care of. Here is what the truck looked like an hour before we left for our trail ride.
[img]
http://www.personainternet.com/sdennie/toughguy/truck/Fresh%20paint%201.jpg[/img]
[img]
http://www.personainternet.com/sdennie/toughguy/truck/fresh%20paint%202.jpg[/img]
[img]
http://www.personainternet.com/sdennie/toughguy/truck/fresh%20paint%203.jpg[/img]
We finaly set out on our ride and I stopped for a background shot before the paint got messed up.
[img]
http://www.personainternet.com/sdennie/toughguy/truck/mlw%20ride%201.jpg[/img]
It was a good thing I did because by the time we reached our destination, the truck was scratched permanently and missing a few mechanical components!
[img]
http://www.personainternet.com/sdennie/toughguy/truck/are%20these%20mine.jpg[/img]
Yes that`s the rear driveshaft in my right hand and my rear shocks in the other. Too much throttle on a steep uphill wrapped the axle so much that the rear u-joint bottomed out and the rear pinion sheared completely.
[img]
http://www.personainternet.com/sdennie/toughguy/truck/broken%20pinion.jpg[/img]
Nevertheless, I was still able to keep going and my flex allowed me to crawl over significant obstacles like the tree stump under the left front wheel in the picture where I am holding the driveshaft. This was despite the fact that I have open diffs at each end. (thus having one wheel drive at the time) By comparison, my friend Marc`s Suzuki Sidekick is running a Dana 44 front and Ford 9" rear with spools in each and my friend Simon`s Toyota Xtracab was running a welded IFS and Lockright rear. (with 36" Super Swampers) In retrospect, forgeting to add a load leaf to the rear spring packs was not the best idea. The flex was there but I would have needed to make some torque rods to control axlewrap.
[img]
http://www.personainternet.com/sdennie/toughguy/truck/bent%20packs%201.jpg[/img]
The truck is back in the shop again while I effect the necessary repairs and modifications to prevent this from happening again.
[img]
http://www.personainternet.com/sdennie/toughguy/truck/back%20in%20the%20shop.jpg[/img]
Funny side note: With the roof rack on, I have to air the tires down to get the truck though the garage door! Doh!
I should have this thing back on the road by next week if I can get my new spring packs in time. I`ve already swapped out the rear axle and am rethinking my rear shock mounts as well as fabbing a control arm to prevent axlewrap.
Sorry for the long winded post. I guess I just got a little carried away!
Toughguy
