Gas Mileage on a 3.4L...
#457218
05/30/04 02:44 PM
the gas mileage on my 96 tacoma 5vze has dropped significantly
its gone from 600km>> to 450km (yeah canadian its about 14.5 mpg) That SUX! and gas is just going up!
The check engine light is NOT on.. could the O2 sensor be bad? or the MAS. The plugs are brand new.
HELP?!
Re: Gas Mileage on a 3.4L...
#457219
05/30/04 06:11 PM
PLUGS ARE BRAND NEW!" that is the first thing i would check! make sure that they are all gaped to the right specs.!!! then get a new o2 if that doesn't work! then the next then the next untill you figure it out! I only get 250 a tank on my 2003 v-6! but i do have alot of weight added, 33's and a very heavy foot with charger and fuel mods. red
2003 TRD EXT.CAB V-6 SR5 supercharger+urd fuel mods 6inch fabtech+1RB 35 BFG MT 4.88's Stubbs sliders
[Re: redtoy92]
#457220
05/30/04 08:24 PM
damn my milage sucks then if your getting 250 to the tank with the charger and larger tires
im lucky to get 230 and thats sticking the needle at E
[Re: redtoy92]
#457221
05/31/04 03:24 AM
Usually 400 miles before fill ups in the warmer weather. But I have the 2.7L stump puller!
#457222
05/31/04 04:58 AM
You should look into cleaning out your throttle body and maybe your MAF sensor as well since you'll have your air tube out. Drop in a can of BG 44K or other injector cleaner for 2 tankfuls and see where your mileage gets you. I say 2 tanks because one can to loosen the depsits and the second can on your next fillup to clean them all out. Keep us updated! BTW, I've been getting about 255 miles per tank ever since I used BG 44K.
[Re: humanoid]
#457223
06/02/04 12:14 PM
my truck had a vacuum leak that ate some gas. the hose had to actually break before the MIL lit up. also check your tire pressure, which is a big killer on our trucks, too.
last fill-up was 21mpg for my in my 5-spd 3.4L x-cab TRD
[Re: humanoid]
#457224
06/02/04 04:07 PM
Toyota Moderator
Have you found any discounts on the BG 44K? <img src="/forums/images/graemlins/frown.gif" alt="" />
Wheeling a Stepside Tacoma on 37s Exploring in a T4R Ltd V8
[Re: Mark in AZ]
#457225
06/02/04 04:43 PM
Mark, try this link... It's one of the cheapest places I've found. http://store.yahoo.com/bbjeep2/jeepbgadfuel.htmlOr, you head on over to the yotatech.com site and there's a memeber by the name of Todd "TOR" who's the main parts guy at Richardson Toyota in Texas. Great prices on anything you need for your rig!
PHP: 7.4.33 Page Time: 3.484s Queries: 15 (0.004s) Memory: 0.6139 MB (Peak: 0.6950 MB) Data Comp: Off Server Time: 2026-06-20 23:57:14 UTCValid HTML 5 and Valid CSS
