Re: Diagram for 91 montero Throttle Position Sensor [Re: jetcitydude] #457601 06/08/04 04:29 AM
jetcitydude Offline OP
vic, can you look up the ground scheme for the radio and vehicle speed sensor. My Chilton leaves a lot to be desired. I have that error code 24 showing now after 2 days of driving. Trying to figure it out. <img src="/forums/images/graemlins/cheers.gif" alt="" />
1991 Montero 3.0 V6 Auto 4X4,1986 Fiero 3.8
Re: Diagram for 91 montero Throttle Position Sensor [Re: Vic Lee] #457602 06/08/04 04:41 AM
Vic, thanks for the post. That should help. One more error code. ECUdirect seems ok. I had to send my unit to them. They could not come up with a core, this took them about a week to 10 days to figure out. I was on travel so it did not bother me. My unit came back spray painted black with stickers that say warranty void if broken. So I have not been able to look inside to see what the really did. I did plug it in and to test it I pulled my engine temp sensor and the ECU did detect the problem. So far so good. I using an ECU I bought off Vbay <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />. I will swap the ECUdirect build back in when I get a chance. I have not used AvPro, but have seen some posts that have a few complaints against them.
Re: Diagram for 91 montero Throttle Position Sensor [Re: jetcitydude] #457603 06/08/04 05:22 AM
Vic Lee Offline
Jetcitydude,
Check your PM's
Vic
1990 Montero 2dr 3.0 Auto Lsd Front & Rear
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5999 MB (Peak: 0.6532 MB) Data Comp: Off Server Time: 2026-11-02 08:48:56 UTC
