Page 3 of 3 1 2 3
Re: Engine lean with increased airflow through larger MAF. Help!?!? [Re: Xanatos] #457951 06/05/04 08:54 AM
randii Offline
Your existing computer is expecting a narrow-band signal, and will not do well with wide-band data, so install the wide-band setup separately.
Dunno which sensor you want to sample -- OBD-II systems are a bugger to work around.
Randii
Re: Engine lean with increased airflow through larger MAF. Help!?!? [Re: randii] #457952 06/06/04 02:34 PM
W
wiguy Offline
from what I understand a maf is basically a heating element that trys to hold a constant temp whem more air go through it has to try harder to stay at that temp. I suspect with your mod it has to try like heck to stay at that temp sending a signal to your computer saying need more gas to make up for all this extra air. Granatelli sells a upgrade maf for cold air intake systems to offset this occurance
just my .02 cent
Goodluck
<img src="/forums/images/graemlins/patriot.gif" alt="" />
mike
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.5926 MB (Peak: 0.6576 MB) Data Comp: Off Server Time: 2026-06-10 03:19:20 UTC
