3vze thermostat seal?
#459379
06/04/04 03:28 AM
I replaced the thermostat on a 94 v6 runner a few months ago and it started leaking recently. Do you guys have any tips on how to seal it when I reinstall?
Re: 3vze thermostat seal?
[Re: eep]
#459380
06/04/04 04:45 AM
That's what happened when I replaced my thermo...turns out it was actually the waterpump leaking. Might want to check that out.
[Re: Robinhood150]
#459381
06/04/04 08:39 AM
I haven't checked the water pump for leakage. I did replace that at the same time I replaced the thermostat. But I can clearly see signs of leaking (dried up coolant) around the thermostat.
What did you use for the seals? I think the stuff I used was Permatex.
[Re: eep]
#459382
06/04/04 06:18 PM
Isn't there an O-ring to seal the housing?
[Re: code33]
#459383
06/04/04 06:32 PM
Isn't there an O-ring to seal the housing? Yeah, extra sealant *shouldn't* be needed since the o-ring around the thermostat seals it all up.
[Re: code33]
#459384
06/04/04 06:41 PM
Isn't there an O-ring to seal the housing? I don't remember now...maybe I was thinking about the water pump or one of the pulley assemblies with the water spout in it. I guess I'll take it off and check the o-ring. thanks
[Re: eep]
#459385
06/04/04 06:51 PM
Good luck EEP. Lemme know if you need help. <img src="/forums/images/graemlins/cheers.gif" alt="" />
e-rox
89 Malljero 4dr V6 94 Monstero SR (sold) 91 GVR4 turbo powa too many mods 83 300TD turbo diesel powa
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6154 MB (Peak: 0.6890 MB) Data Comp: Off Server Time: 2026-06-21 04:31:00 UTCValid HTML 5 and Valid CSS
