What's the best "SST" to jumper the computer block #461044 06/07/04 08:05 PM
BallaRat Offline OP
You know...when timing a 22RE you're supposed to jumper the T1 and E1 connectors. This makes the timing come down (ok, retard, but why must we always be a bunch of retards? <img src="/forums/images/graemlins/smile.gif" alt="" />). You set it at 5 BTDC then when you remove the jumper it should climb to about 12BTDC. Easy, except lately when I use a heavy gauge paper clip it just doesn't make the contact well enough to cause the timing to come down unless I hold it just right. Now since I ain't got 3 hands (wonder why that is) I can't hold the jumper, the timing light, and adjust the distributor at the same time.
What's everyone else use to jumper those? I think I got my timing OK now, but had to kind of guess, check, readjust, etc....
Don West
Gettin'Off4x4 Member
'94 Reg Cab, 1" BL, 33 MTs, Detroit f/r, 4.88s, dual Marlins, blah blah woof woof
Re: What's the best "SST" to jumper the computer block [Re: BallaRat] #461045 06/07/04 08:13 PM
G
GeriatricToy Offline
I use two male spade connectors. They fit in real nice and tight. <img src="/forums/images/graemlins/shocked.gif" alt="" />
2000 Tacoma SR5 - Bone stock 'cept a little bling.
2000 Tacoma SR5 - Bone stock.
Re: What's the best "SST" to jumper the computer block [Re: BallaRat] #461046 06/07/04 08:14 PM
Esquire812 Offline
Busted in half paper clip. Rigid enough to push through the anti-corrosive slime and make good contact with the terminals. Flexible enough to make the T-E1 jump and expand to make the Fp-B+ jump. When done, slide one end done through the mounting tab of the diagnostic box and it will be there the next time you need it.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: What's the best "SST" to jumper the computer block [Re: GeriatricToy] #461047 06/07/04 08:29 PM
4Crawler Offline
That's what I use on my '85 (different type of connector):
Short length of wire and two bare male spade lugs, of the right size, crimped on the end.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6027 MB (Peak: 0.6587 MB) Data Comp: Off Server Time: 2026-11-17 13:49:21 UTC
