Re: Bolting also to the pinch seam? [Re: skidplate98] #462781 06/15/04 03:42 AM
BobShaw Offline
Question?
I have knerf(?) bars bolted to the frame. They stick out and protect the rocker pannels. They also work great to keep the body off the ground when you are sitting on 2 wheels and the knerf bar in a ditch at 30 degrees. How do your "sliders" work and are they better than the "T bone" protection of the knerf bars. How the heck do you spell knerf?
Bob Shaw
superchief87@adelphia.net
Re: Bolting also to the pinch seam? [Re: BobShaw] #462782 06/15/04 04:09 AM
FrankR Offline
The same way you spell .... knumber, knice, kneat, knipple or macaroni & knoodles....... "nerf". <img src="/forums/images/graemlins/cheers.gif" alt="" />
Frank
Re: Bolting also to the pinch seam? [Re: BobShaw] #462783 06/15/04 06:38 AM
Nerfs are typically cosmetic by design and while can handle light abuse will fail much sooner than sliders.
Unless custom fabricated, most nerfs are built using .120" thick (aka ".120 wall") steel tubing which is fine for most "light" hits but not strong enough for harder hits taken when rock crawling or going over more difficult terrain.
Sliders are purpose build with long term abuse and survivability in mind. In most cases, I recommend a minimum of 220 wall steel tubing to minimize the number of frame attachments (2 or 3) and while still survive repeated hits off road.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6034 MB (Peak: 0.6572 MB) Data Comp: Off Server Time: 2026-11-18 11:54:28 UTC
