Transmission swap #462811 06/11/04 08:06 PM
E
extremesolo Offline OP
Is it possible to swap a transmission from an 83 into an 85 pickup? What are the differences between the two and how can I tell which one is currently installed if I am under the truck looking at it (physical features or markings)? I found an 85 that needs a transmission and i have also found a cheap 83 transmission. Will they be a direct swap and no problems for the transfer case and driveshaft or will I have to make other modifications as well? Thanks, Andrew
1987 4Runner - 22RE, 290,000 miles 63" chevys, double shackle, BJ spacers, downey IFS truss, extended differential breathers, 33x10.50 BFG MT's. Soon to come - aussie locker in rear
Re: Transmission swap [Re: extremesolo] #462812 06/11/04 08:18 PM
Red_Chili Offline
Toyota Section Staffer
Not a great idea. Going the other way would be. You would be going through a little pain to end up worse off. That may explain the price.
Why not just rebuild the 85 tranny?
-Bill
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5867 MB (Peak: 0.6347 MB) Data Comp: Off Server Time: 2026-06-16 11:27:42 UTC
