'95 Rodeo (1st gen) ... as most of you know, the power locks are quite flimsy since all you do is pull the driver door lock up/down and the rest go up/down - there's no "button" for it on the panel. I've had the passenger door lock "broken" for a while now... have to lock/unlock that particular one manually... because my passengers pull on it before I can open it for them... and today my rear driver side decides to break because it's been pulled manually too much. Anyone else seeing this ?
Not yet, but my 95 Trooper does have a button on the panel.
I have keyless entry so this becomes more a P.I.T.A... it'll unlock ok, but never go back down unless I manually push it. Questions:
1) Is this something I can easily fix myself ? I recall asking a while ago and there's something with the actuators. Are the parts inexpensive and easy to fix ?
I'd bet that the parts aren't
too bad, even at the dealer, and that if you can find the broken parts on your vehicle that they'd be dirt cheap at a junkyard.
2) If I get a remote start system, that comes with a new keyless entry... will the guys fix these problems for me ?
Probably not. Especially if it's a physical problem (as opposed to electrical).
3) More of a long shot... I've got dents on the passenger door anyway and since that lock is broken too... how easy is it to replace the entire door from one from the junkyard or something ? Any other ideas to find doors ?
Actually replacing the door shouldn't be too bad. If you don't mind a multi-colored vehicle, it should be even easier. Finding a junkyard vehicle with matching paint can be tough--even if the original paint was the same color. Aside from forums like this one (ITOG, PlanetIsuzoo) maybe eBay?
