Another dumb tire question #464598 06/15/04 08:57 PM
hunterdan Offline OP
Im researching tires again. I've finally made the decision to switch to 33's. But since I dont have a body lift decided to only go for 33-10.50's since I dont have the cash for new wheels, and I kind of like the new paint job I have on my snowflakes. Heres the scenario. I have a 92 Rodeo with shackles out back and cranked t-bars in the front. Not exactly sure how much lift it is, but it seems to be in the 2" range. I'm not afraid to do too much trimming if I have to, as long as I can get home from the shop to do the trimming. It seems to me that if they rub, it will be in the fender well right where the front mudflaps would be if I still had them on there. The front plastic wont seem to interfere much, if at all. I measure the wheel opening in the front and its about 35" and the rear is about 34.5". That seems to be enough for the 33's. Currently Im looking at the BFG ATs for a little bit better mileage over the MTs. Am I correct in assuming these tires will fit with basically no problems at all?
Just a side note, I posted in the trail talk section about the Bloomsburg 4x4 Jamboree. Would be nice to see a bunch of Zu's there.
Thanks in advance
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
Re: Another dumb tire question [Re: hunterdan] #464599 06/15/04 09:09 PM
O
OffRodEO Offline
there will be a problem. Do you have the spring upgrade or just the shackles?? k on the rear it might not be a problem (besides rubbing on the inner wall) but the front, no matter how much suspension lift you have it will still "stuff" to the stock position. Imagine having your back right tire up on a hill, it will make your front left tire stuff that tire in the wheel well. If you put a body lift, it wont be able to reach the fenders.
From what ive studied and read, you wont be able to safely put 33's on. I havent seen anyone yet without a body lift that has 33's
i have 32X 11.50's i had to take my front mud flaps off because i need that extra 1/4 inch, and when i stuff my tire i still rub
kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
Re: Another dumb tire question [Re: OffRodEO] #464600 06/15/04 09:14 PM
BigSwede Offline
I know Mike Bantz ("sweater") had 33x10.5 BFG ATs on his Rodeo (at least until he went with a solid axle <img src="/forums/images/graemlins/notooth.gif" alt="" /> ), but I don't know what he had for lifts on it at the time...
Serenity now!
Re: Another dumb tire question [Re: BigSwede] #464601 06/15/04 10:48 PM
CPOM Offline
I have 33x12.5 MTRs on my truck with no BL.
Then again, the front is cranked to the point where it does not leave the bumpstops, and I used different wheels.
CHRIS
98 Amigo, 92 Pup
Re: Another dumb tire question [Re: CPOM] #464602 06/16/04 04:24 AM
What kind of wheels with what backspacing are you using. I really like the way your truck looks, and hope to get my rodeo look very close to it. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I plan on having the leaf pack beefed up a bit because its starting to sag, and that should lift the rear more, and if I have to, I can crank the front more. Im not a fan of body lifts, but then again Ive never installed one. After wheeling with mike, Rodeoguy, he made my fairly gnarly 31's look puny, and I feel that my Rodeo would look way cooler with 33's anyway. I know the 12.50s will rub, which is why I plan on sticking with the 10.50s, and because a narrower tire does better on snow and slush in the winter time. Thanks for your help again.
Dan
Re: Another dumb tire question [Re: hunterdan] #464603 06/16/04 04:31 AM
9
94redrodeo Offline
The rear on my rodeo stuffs fine I have 33x12.50's and a 2 inch suspension lift I'm not saying you won't have a problem but I don't
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: Another dumb tire question [Re: BigSwede] #464604 06/16/04 04:31 AM
sweater Offline
3" Calmini lift. Nothing more. And I kept those 33's on it pretty far post-SAS, until I ripped back into it this spring for the Chevy axle. Have I mentioned how wide that thing is?
Plain old rockcrawlers from Discount Tire, etc. You're going to rub. You're going to lock up your junk on full compression. But I never trashed my tires or anything, and backing off on the wheel a little when locked up like that always got me out of any inconvenience the rubbing caused.
This was, however, before I was totally okay with cutting stuff off my rig.
Go for 33's. Most people think that 12.5's are what you need, but those 10.5's were pretty damn sweet off road (mostly rock out here, though - you've got a little more mixed mud/rock probably). But just suck it up and make 'em fit. You'll always wish you had gone to 33's if you go for anything less, and it'll cost you more in the long run when you get a new set of tires after a year. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Another dumb tire question [Re: sweater] #464605 06/16/04 04:40 AM
Thanks... Thats pretty much what I wanted/needed to hear. <img src="/forums/images/graemlins/smile.gif" alt="" /> I pretty much figured I'd do whatever was needed to get them to fit. If need be, the little 5 pound sledge might be just the ticket to get them to stuff without rubbing. Atleast on my rodeo it takes 33's to rub while on my friends cherokee, 31's were rubbing on his control arms at full lock while it was sitting level. Thanks a ton <img src="/forums/images/graemlins/kewl.gif" alt="" />
Dan
Re: Another dumb tire question [Re: hunterdan] #464606 06/16/04 05:31 AM
I may look for a set of wheels if I can find them. If I go with a 15x8 wheel, what backspacing would be the best. If they stick out some, not too much, it wont bother me. Is it somewhere in the 3.75" range? Thanks again
Dan
Re: Another dumb tire question [Re: hunterdan] #464607 06/16/04 03:09 PM
sweater Offline
Dan
I'm going to think it was something like that - 3.75ish sounds about right. If you buy the off-the-shelf cheapo black rock crawler rims, you're probably going to get what I have on my Trooper now. But those are 15x8 rims, and I went with the non-standard 10.50's (I remember everyone thinking I was kinda weird for going that route). But let me put it this way:
On my Rodeo, I could easily lock up those 10.50's, so traction wasn't an issue. Even more so on the Trooper - I actually think that a 12.50 tire would spread out WAY too much friction and end up being dangerous. Unfortunately, the other day someone cut me off, I locked up the Trooper, got it sideways, and the co-worker who was in traffic behind me said "You were going over. I don't know how you didn't do it, but you were going over." I think I would have been sliding more with 12.50's.
Moral of the story: I fully believe that you need to make sure you maintain a little smaller contact patch, and 10.50's are a great choice. Also, BFG is one of the only companies out there (I think) that makes both a really durable mudder and an AT in a 10.50 size.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6452 MB (Peak: 0.7680 MB) Data Comp: Off Server Time: 2026-11-17 14:22:15 UTC
