intermittent Manifold Differential Pressure Switch - 3.5l #467537 06/22/04 05:32 PM
davemtb Offline OP
I've been getting check engine lights from code P1400 (OBDII) from the day I bought my truck two months ago. Some web surfing led me to the Manifold Differential Pressure Switch. I've reset the code several times now, and it shows back up within a couple hundred miles. After 5 or 6 times, I still have not been able to pick up a pattern as to what might be causing the switch to read out of range.
Last night I put a splitter & vacuum gauge at the port right by switch on the intake manifold. At idle, I had 18-20" Hg. Revving the engine using the throttle cable of course caused the vacuum to dip. If I revved hard enough, the gauge would shoot all the way back to 0". Is that normal? I used carb cleaner and light sprays of ether at various places around the manifold looking for vacuum leaks, but didn't find any. I confirmed a few weeks back that the lower plenum is the updated part number.
I figure that either the switch is intermittently shorting/malfunctioning, or something is causing it to drop out of range. I assume the switch reports lack of vacuum. I have never been of the part swapping mentality, and would like to know how to test the switch as well as what might cause the condition. Anyone have any ideas what to do next?
Thanks in advance,
Dave in KC
Dave Smith
'96 SR - 31x10.5 Tires
"Facts are meaningless. You could use facts to prove anything that's even remotely true!" Homer Simpson
Re: intermittent Manifold Differential Pressure Switch - 3.5l [Re: davemtb] #467538 06/22/04 06:06 PM
The primary purpose of the MDP sensor (as far Mitsubishi MFI) is to verify EGR operation (OBDII compliance). The only way to properly check it is to see what values it is showing under specific vacuum loads. However, i don't know what the resistace values would equal to at a specific vacuum amount. With a MutII scan tool, you can see what the MDP is "seeing" and compare it to an actual vacuum gauge hooked up the the intake. More than likely- the MDP sensor has an intermittant failure that is causing your problem. If your MDP vacuum values are low , you can try removing the MDP and cleaning out the small pin hole port that it's mounted to to eliminate any blockage from carbon and see if that helps.
Joel, CA
Re: intermittent Manifold Differential Pressure Switch - 3.5l #467539 06/22/04 07:24 PM
davemtb Offline OP
Thanks Joel. I don't know if my values are low or not. I pulled the switch and wiped it off, but there was no buildup. I also made sure the bleed hole in the manifold was not blocked and reset the check engine light. I didn't find anything that makes me think this will keep the light from returning. <img src="/forums/images/graemlins/frown.gif" alt="" />
So an intermittent failure could be a ground, or the MDP itself? I am assuming from your description the MDP is a transducer that reports data to the computer rather than a DP "switch" that opens/closes at a given DP.
I think I read the input signal voltage to the MDP is 5v. I need to find that info again and find out what type of signal voltage it should be returning to the computer.
Thanks again.
Dave Smith
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5922 MB (Peak: 0.6476 MB) Data Comp: Off Server Time: 2026-11-16 01:40:49 UTC
