need help...v6 third in a 4 cylinder housing #468968 06/27/04 12:51 AM
wlew Offline OP
I have a 85 4runner with a 4 cylinder third that is bad. I purchased a v6 third with precsion gears and an ARB. Everything I've read say the 4cylinder and v6 thirds are interchangeable. I took out the 4 cylinder third and trying to install the v6 third and I can't get it to fit. Do I need to modify the housing? Thanks in advance for the help
Wilson
Re: need help...v6 third in a 4 cylinder housing [Re: wlew] #468969 06/27/04 01:00 AM
ZUK Offline
so it sounds like the ring gear teeth are catching on the housing? What ratio is in it?
mostly stock
Re: need help...v6 third in a 4 cylinder housing [Re: wlew] #468970 06/27/04 01:08 AM
4Crawler Offline
What is not fitting? I run a 4.88 geared V6 3rd in my '85 housing. Usually you may need to grind a bit off the two notches in the housing to let the ring gear teeth fit past, I had to do that with the 5.29/4cyl 3rd I used to run. I also find that opening up the mounting holes in the 3rd a tad helps a great deal. I use a bit that is 1/64" to 1/32" larger than the existing holes to make it easier to slip the 3rd member in place over the studs. Makes it so much easier when you are laying on your back trying to wrestle the thing into place.
Re: need help...v6 third in a 4 cylinder housing [Re: wlew] #468971 06/27/04 01:20 AM
wlew Offline OP
It feels like the ring gear is hitting the housing. It's 5.29 gears. I'll try grinding the housing.
Thanks
Wilson
Re: need help...v6 third in a 4 cylinder housing [Re: wlew] #468972 06/27/04 01:43 AM
4Crawler Offline
5.29s seen to be the hardest to install, the tips of the ring gear teeth stick out farther. Either grind the notches in the housing a little deeper (there are two pieces of steel there, often the two don't line up perfectly and there is a little step - grind that flat) or try rocking the pinion flange back and forth as you work the 3rd into place, that's often all it takes to get the gears to fit into place.
Re: need help...v6 third in a 4 cylinder housing [Re: 4Crawler] #468973 06/28/04 07:21 AM
Vonka Offline
I have a V6 third with 4:88's on my 4 cylinder housing.It went in like it didn't want to fit .So I kept trying to find the right angle and it went right in.The axles will fit perfect once your V6 third are in.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: need help...v6 third in a 4 cylinder housing [Re: wlew] #468974 06/29/04 07:24 AM
wlew Offline OP
finally got it in after a little grinding. thanks for all the help.
Wilson
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6193 MB (Peak: 0.6938 MB) Data Comp: Off Server Time: 2026-06-23 03:59:55 UTC
