Page 2 of 4 1 2 3 4
Re: I did not make the stairs in Hollister Hills Vehicular Recreation Area [Re: Scott F.] #469082 06/28/04 02:41 AM
holger Offline OP
Simply put, wheel base!
yeah, I felt so bad when I saw a Suburban making
those stairs effortlessly...
Your not the only one, I have done tons of trails with no problems, but forget the stairs it just makes me look like a suck <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> driver.
Scott F.
Scott, did you make that huge sand hill ("truck hill")
at the far side of the area ? I found that hill only
by the end of the day, my fellow passenger was already tired
and scared, so I did not try to make the hill.
Is it really difficult, did you go thru it ?
Regards,
Oleg
Re: I did not make the stairs in Hollister Hills Vehicular Recreation Area [Re: holger] #469083 06/28/04 03:07 AM
rheteric Offline
Oleg,
It's good to see our 2nd gen Rodeos can be put through their paces and still come out alive, whether successful or not.... <img src="/forums/images/graemlins/kewl.gif" alt="" /> I think you did us good!
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
www.burnlounge.com/mp3me
'00 Rodeo LS 4x4; "K&N" cone filter; S/S Manik Front, Rear, & Nerf; 'Modest' sound system; 1.5" R'ooper lift, 265/70/16 Dunlop RVxt, Skyjacker Hydros, OEM LSD (sans G80 code)
Re: I did not make the stairs in Hollister Hills Vehicular Recreation Area [Re: rheteric] #469084 06/28/04 08:29 PM
mlclark Offline
Isuzu Moderator
OK, this thread is back. Let's continue the discussion about wheel base, tire pressure and tire type.
Also, does anybody have any pictures of this obstacle?
Michael
Re: I did not make the stairs in Hollister Hills Vehicular Recreation Area [Re: mlclark] #469085 06/28/04 08:57 PM
W
Wayne Offline
I'll re-ask: Why does the Rodeo get stuck? Is it wheelbase? Is it hiting front and rear tires at the sime time, then having to pull the weight of the vehicle up with only the edge of traction on all 4 wheels?
Subrubans were mentioned doing it without much problem--I picture high-centering with a longer wheel base. Wouldn't a Jeep/Samuri (short wheelbase) have the best run at it, getting on one stair at a time?
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: I did not make the stairs in Hollister Hills Vehicular Recreation Area [Re: Wayne] #469086 06/28/04 09:37 PM
holger Offline OP
no, it did not. The surfice was fairly firm - it
was PAVED, and it was steep uphill.
You cannot get stuck under these conditions <img src="/forums/images/graemlins/smile.gif" alt="" />
yep! I had not enough traction to pull me up.
That Suburban on 35" (or may be even 38") had plenty
of clearence over the steps. I do not know about
Jeeps/Sammies - they would have to climb steeper
angle than Suburban. I saw a short wheelbase vehicle
making those steps, but it was a buggy with something
like 40" wheels.
But if a member of this board did it on his 29"s, than
it must be not so difficult for an experienced driver...
Oleg
Re: I did not make the stairs in Hollister Hills Vehicular Recreation Area [Re: holger] #469087 06/28/04 10:21 PM
BigSwede Offline
I did not air down. I had no air pump with me to
air it back. My tires have 35 psi. May be, this makes big
difference.
That's it right there...huge difference in traction when aired down. That's why everybody goes through the PITA of airing down, it's worth it if traction is marginal.
Serenity now!
Re: I did not make the stairs in Hollister Hills Vehicular Recreation Area [Re: BigSwede] #469088 06/29/04 12:46 AM
Simply put, holeg agreed that he just needs to air down. I air my MTs to 10psi and climb like a goat on those steps with 29''ers! <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: I did not make the stairs in Hollister Hills Vehicular Recreation Area #469089 06/29/04 01:11 AM
W
Wayne Offline
I'll re-hit something sent earlier. I'd love to see a picture, if someone has one, so I can better understand.
Re: I did not make the stairs in Hollister Hills Vehicular Recreation Area [Re: Wayne] #469090 06/29/04 01:13 AM
holger Offline OP
My fellow made some pictures, I'll ask him to send
them to me and I'll find out if there are pictures
of the stairs.
Re: I did not make the stairs in Hollister Hills Vehicular Recreation Area [Re: holger] #469091 06/29/04 01:33 AM
pucci Offline
here's pics I found of it (not mine). kinda hard to see from the shadows, but you get the idea:
a large staircase of logs and rocks. It was surprisingly steeper and more difficult than it looks
2.6 Trooper
2.0 Impulse Turbo
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6413 MB (Peak: 0.7515 MB) Data Comp: Off Server Time: 2026-06-20 16:36:28 UTC
