Re: How Do you get stuck COTTERPINS out of Balljoints??? #469875 06/29/04 07:04 PM
foxtrapper Offline
Cotterpins are soft, they drill out quite easily.
Re: How Do you get stuck COTTERPINS out of Balljoints??? [Re: foxtrapper] #469876 06/29/04 10:50 PM
F*CK, i was drilling through them, 1 is done, but the lower one the drill bit broke off inside it and i can't get that out now, it's a bout 1/2 way through damnit, and that drill bit will be a Biotch to drill through cuz they're so hard. <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: How Do you get stuck COTTERPINS out of Balljoints??? #469877 06/29/04 11:05 PM
Esquire812 Offline
Ouch, that ones gotta hurt. Only suggestion I can offer is...."Know anyone with a press"???
Once a drill bit decides to park itself in the hole, Joe Shadetree mechanic is usually screwed.
Feel bad for ya.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: How Do you get stuck COTTERPINS out of Balljoints??? #469878 06/30/04 11:30 AM
foxtrapper Offline
Get another bit and drill from the other side. Once you've gotten the remains of the cotter pin clear, you can use a prick punch and push the broken off drill bit out. It will most likely come out best going backwards (push the tip of the bit).
Re: How Do you get stuck COTTERPINS out of Balljoints??? [Re: foxtrapper] #469879 06/30/04 04:02 PM
A
averkam Offline
Try a sawzall right through the middle of the nut and stud.
Or a cut-off wheel in an angle/die grinder. If you do not have one you can rent one for a couple bucks. You can put a cut-off wheel on your drill too. That would easily cut through the whole mess and your cotter pin will no longer be part of the truck. Leaving part of a nut and a very short stud.
2000 Ext Cab SR5 4WD 2.7L 5-speed.
Re: How Do you get stuck COTTERPINS out of Balljoints??? [Re: averkam] #469880 06/30/04 04:19 PM
Re-read the post. He has the nut off the ball joints allready. Just need to get what's left of the cotter pin off w/out ruining the ball joints.
Re: How Do you get stuck COTTERPINS out of Balljoints??? #469881 06/30/04 04:29 PM
A
averkam Offline
Sorry, I missed that part. Just buy a new ball joint? They are not that expensive.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6172 MB (Peak: 0.6956 MB) Data Comp: Off Server Time: 2026-06-21 12:54:34 UTC
