Newb question about Ultimate Dual Cases. #472408 07/04/04 04:40 PM
Im just curious, i was looking at a friends Ultimate dual case setup the other day and seen 3 sticks. Actually... 4 counting the transmission. Ok now i know that the transmission stick is 1st gear to 5th with Reverse. One of the T-case sticks is 4H,4L and Nuetral. Im guessing that the other half t-case stick is just High, Low correct? But what the hell is the third stick for??? Ive seen Marlin Crawler cases and Jeepeaters but those all have 2 sticks...4H,4L, Nuetral on one stick.. and just the High-Low on the other. Some clarification would be great, thanks!
Re: Newb question about Ultimate Dual Cases. #472409 07/04/04 05:05 PM
surlynkid Offline
twin sticks on rear case. one does high/low and one does 2wd/4wd. you can use it to run 2wd low which is not possible with teh stock setup.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Newb question about Ultimate Dual Cases. #472410 07/04/04 05:09 PM
4Crawler Offline
You can put a twin stick shifter into a stock t-case with some minor work:
Twin-stick shifter install.
Re: Newb question about Ultimate Dual Cases. [Re: 4Crawler] #472411 07/05/04 05:46 PM
Interesting.. thanks for the help and link guys.
Re: Newb question about Ultimate Dual Cases. #472412 07/05/04 06:14 PM
There are a lot of different choices on the number of transfer cases and the shifters used.
Marlin's truck has a total of 5 shifters:
Transmission
First crawl box (2.28)
Second crawl box (4.7)
Transfer case high/low (4.7)
Transfer case 2wd/4wd
Re: Newb question about Ultimate Dual Cases. #472413 07/08/04 12:31 AM
bud r Offline
Some people are overachievers! smile
Thank God! smile
Bud R 828-572-1202
98-04 Tacoma, locked, dual cases, ready to go smile
http://www.budbuilt.com
Re: Newb question about Ultimate Dual Cases. [Re: bud r] #472414 07/18/04 08:16 PM
It also has around ... hmm.. 1043:1 crawl ratio?!
haha... geez thats insane...
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6069 MB (Peak: 0.6840 MB) Data Comp: Off Server Time: 2026-11-17 04:57:24 UTC
