Page 5 of 5 1 2 3 4 5
Re: Homebrew U-bolt flip questions #47384 06/22/03 09:33 PM
I agree, WHY SUA?
That is a LOT of loading on that plate, once it bends far enough, it will stress the bolts to failure....
Re: Homebrew U-bolt flip questions #47385 06/22/03 09:36 PM
And that shock setup looks trick, but really looks like it just adds load tot he shackle preventing flex...does it really work?
Re: Homebrew U-bolt flip questions #47386 06/22/03 09:49 PM
4Crawler Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Bill_Morgan:
<strong>Same plates on the front? Problems wrapping 5/8 Ubolts around the front axle? Or does it fall together like a Lego set? I would relieve the sharp edge is all, but that's 5 minutes with a grinder.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I used 3.25" wide u-bolts up front vs. 3" for the rear. Its a bit of a chore to bend the 5/8" u-bolts to fit the passenger side. I used a hydraulic press to put enough bend in them the fit well.
Re: Homebrew U-bolt flip questions #47387 06/23/03 06:09 PM
Red_Chili Offline
Toyota Section Staffer
As it turned out, I used NAPA 5/8" 3" ubolts, three of the four fit easily with a little press 'adjusting'. For the pesky inside passenger one, I still went with 3", but opened it up a little by heating and bending so it was just a little more like V than U, then bent the front leg back with a press to conform to the odd axle angle (using as a template the cheap bent 1/2" ubolt that came with a certain vendor's Ubolt flip kit). Practically fell into place.
I elected to weld an additional 1/4" plate to the top of that vendor's 1/4" thick plate after making the plate flat again with the press. Allowed recentering the holes for the 5/8" Ubolts, as well as repositioning the axle further forward. Hell for stout now. I'll do something similar in the rear soon.
-Bill
Re: Homebrew U-bolt flip questions #47388 06/24/03 04:42 AM
Lou Bell Offline OP
Bill,
Can you please post the part #'s for the 3" u-bolts? Did you get them from your local NAPA or at NAPA online?
'87 4runner 37x12.50x15 MTRs
SAS, 4.88's, rear+front e-lockers
4x4Him --- Christian 'wheelin
4x4Him National Forum
Re: Homebrew U-bolt flip questions #47389 06/24/03 04:51 PM
Red_Chili Offline
I don't have the part numbers handy, but just went into NAPA and asked for 5/8" x 3" x 7.5" long or so, and they were in stock. ~$7 each. You want a longer one (I believe I measured ~11.5"? Measure yours if you are doing the front solid axle) for the inside passenger front U bolt, and they had to get it from the warehouse. The 9" long ones, which I need for the rear, are more like $10 each and they had to get them from the warehouse. If you aren't running a block, thick springs, and fat plates you can get away with the 7.5-8" ones. Measure twice, order once. You can always go long and do a Sawzall adjustment <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" />
This just in...
all 5/8" U bolts from NAPA-
3" x 7.5" 6504044
3" x 9" 6504050
3" x 11.5" 6504052
Like I said, you may need something a little longer/shorter, so measure.
<small>[ June 24, 2003, 12:13 PM: Message edited by: Bill_Morgan ]</small>
-Bill
Re: Homebrew U-bolt flip questions #47390 06/24/03 08:18 PM
Red_Chili Offline
<img border="0" title="" alt="[Mad]" src="images/icons/mad.gif" /> The part numbers are not correct, and neither were the U bolts this afternoon. The ones tomorrow will be...
Its only as good as the counter guy I guess.
-Bill
Re: Homebrew U-bolt flip questions #47391 06/28/03 08:34 PM
matts Offline
I am also assuming that this discussion is aimed at the rear axle. A u-bolt flip looks like it would be a little more complicated in front. looks like you'd need a combination of square and round bent bolts. I've heard that there are shops that will custom bend u-bolts; anybody want to recommend one that will take an order over the phone and ship the finished product.
If anybody knows the dimensions of the bends or where I can find that I'd be glad to learn about it. Thanks
Matt
<small>[ June 28, 2003, 03:36 PM: Message edited by: matts ]</small>
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Homebrew U-bolt flip questions #47392 06/28/03 09:13 PM
4Crawler Offline
I run the following:
Front: Rancho RS17436 5/8x3.25x8.75
Rear: Rancho RS17531 5/8x3x9.25 (for '86+)
Both round bottom u-bolts.
Re: Homebrew U-bolt flip questions #47393 06/29/03 01:01 AM
matts Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by 4Crawler:
<strong>I run the following:
Both round bottom u-bolts.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Thanks Roger. You are a bottomless well of precious toyota info.
If I run Old Man Emu's in the front I'll probably need longer bolts. Can Rancho supply those? Where would I get a great mail order deal on the aforementioned u-bolts? Thanks
Matt
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.007s) Memory: 0.6408 MB (Peak: 0.7479 MB) Data Comp: Off Server Time: 2026-11-16 08:32:15 UTC
