Re: Homebrew U-bolt flip questions
#47374
05/16/03 06:31 PM
Toyota Section Staffer
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by H2ohs: <strong>Thanks Lou. As a follow up- I emailed that drawing to a lil shop in town yesterday and picked the plates up today. Just did a test fit and everything is fine! Allan 87 Turbo 4Runner</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Allan- Thanks for posting the Ubolt plate! I have, um, the same front plates that 4Crawler mentioned, and want to replace them... Same plates on the front? Problems wrapping 5/8 Ubolts around the front axle? Or does it fall together like a Lego set? I would relieve the sharp edge is all, but that's 5 minutes with a grinder. Your email is blocked and PMs are not enabled...
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
#47375
05/16/03 06:53 PM
Sorry, my profile is fixed. A few questions have been thrown to me that I am unsure of myself. 1- Would the same Plate work for the front axle? (EricBeebs- Any idea?) 2- Would this plate also be OK for other generation 4runner/Pickups (I used on 1st Generation). Does anyone know if other years are the same? Thanks, Allan
#47376
05/19/03 03:54 AM
I have the same question... will this work on a 92 p/u?
Thanks
Jason
#47377
05/21/03 05:42 AM
so.....anyone with answer to weather this plate will work on the front too? what's the part no. for the rancho 5/8 u bolts?
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are. It's freedom OF religion not from. 95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
#47378
05/20/03 08:50 PM
Anthony1
I think this thread may have died from old age...
#47379
05/20/03 09:30 PM
TTT I believe in resurrection. I have a question unanswered, above.
#47380
05/22/03 05:58 AM
I don't really know the answer but the 'spring width' is gonna determine the bolt hole location & the width of the 'plate'.
so the question still begs, Does the larger plate thickness & larger diameter u-bolts interfere with anything on the front toy axle or sas's???
Toy4x 90 ExCab SR5 V6 Auto In need 99 Taco samesame(ish)
#47381
05/22/03 01:39 AM
Toyota Moderator
I don't know if it would work on a front Toy axle since I don't have one, but I know it would work on the driver's side of a D44. <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" />
The dimensions that determine the bolt locations on the plate are the spring width and axle tube thickness. So since the springs are about 2.5" wide and the tube is 3" thick, the distance between the inside edges of the bolt holes have to be about or at least that...
So.... to figure out where to drill your holes, add the diameter of one bolt hole to the distance you need to clear. For the rear plates, one dimension is 2.5" + 11/16" = 3-5/16", the other one is 3" + 11/16" = 3-11/16". Definitely not rocket science. <img border="0" alt="[Drunk]" title="" src="graemlins/drunk.gif" />
So the 3-5/16" dimension should be the same front or rear, the other one just depends on your axle tube thickness.
#47382
05/22/03 01:45 AM
Toyota Moderator
To answer Toy4x's last question- ANY u-bolt flip is going to interfere with the stock push-pull steering. Simply putting in thicker springs will too.
With crossover (SAS), it doesn't really make any difference. I'm using the stock Chevy front plates and they're thicker than 1/2"...
<img src="http://home.4x4wire.com/erik/pics/fordyce02-10/faxle3.jpg" alt=" - " />
#47383
06/21/03 01:23 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by ZUK: <strong>In the 5th pic in this link http://dreamwater.com/zuk/sua.html I am using a 5/8" killer plate with 5/8" u-bolts....the plates were "stressing" at a mere 100 ft/lbs......the packs kept loosening up cause the plates kept giving more and more.....problem went away with 2 pieces of flatstock of dimensions .25x1.25x3.5 welded on the front and back side of the flat plate....beefed it up 10 times. Now when I tighten up the u-bolts I don't feel the plates giving anymore. By the way, that SUA is startin to grow on me!</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Your plates are bending because your leaf UNDER and the truck weight is on the PLATE not directly on the Axle Why are you Leaf Under and not over????? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
