Question about the stock luggage rack? #474727 07/10/04 04:33 PM
TeaQue Offline OP
I was taking off my luggage rack today to paint it black with some bed liner stuff my buddy gave me (fading luggage racks seem to be very common on Gen II montys--I see them on every single one in my area)
anyways, I got the rack off and looked back at my truck and realized I liked the way the truck looked with it off much better!
My question is this: if I don't seal the holes from the screws that hold in the luggage rack, will they hold/leak water into the cabin?
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Cheap Pilot Fog lights
Re: Question about the stock luggage rack? [Re: TeaQue] #474728 07/11/04 02:35 AM
motero Offline
most likely going to leak. I would use the bolts that came out and a little silicone on the threads to plug the holes.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Question about the stock luggage rack? [Re: motero] #474729 07/11/04 04:09 AM
They seem to be just nutserts, so I would definitely expect them to leak. I did the silicone on mine. One thing I didn't do, but probably will at some point is get some regular pan head screws. The ones for the rack have a stand-off part for passing through the rack. The screws will stick up from the roof about a 1/4" or so.
Re: Question about the stock luggage rack? [Re: motero] #474730 07/11/04 07:54 AM
Angelo Offline
Took mine off about 4 months ago. No leaks so far. Filled them up with silicone.
later,
Angelo
Re: Question about the stock luggage rack? [Re: TeaQue] #474731 07/11/04 08:16 AM
Skinnybloke Offline
If you use a silcone sealer, make sure it is a "neutral-cure" type. If it smells of vinegar or ammonia, don't use it.
EDIT: All holes in rooves "leak", it's just a matter of time.
It's time for my pill now!
93, 3.0L LWB, Pajero. 200K klm,s.
91, Mazda Bravo
Re: Question about the stock luggage rack? [Re: TeaQue] #474732 07/11/04 09:57 AM
Yes it will leak. I removed the flimsy stock rack, sealed the holes with silicon and put a yakima rack on. Looks much better.
Re: Question about the stock luggage rack? [Re: TeaQue] #474733 07/11/04 03:46 PM
TeaQue Offline OP
Thanks guys.
I figured it out for myself because you guys took too long to reply (KIDDING! <img src="/forums/images/graemlins/smile.gif" alt="" /> )
Actually I was clay barring my roof where the rack came off because it was so grimy and i had my face over one of the holes when my g/f accidentally slammed one of my doors and air gushed out the hole into my face <img src="/forums/images/graemlins/lol.gif" alt="" />
I just put the screws back in for now because I was out of silicone sealent <img src="/forums/images/graemlins/kewl.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6149 MB (Peak: 0.6929 MB) Data Comp: Off Server Time: 2026-05-29 16:37:26 UTC
