Re: Does this sound logical? Little grounding strap is the root of all evil? [Re: JLEMOND] #475897 07/15/04 07:17 AM
mlclark Offline
Isuzu Moderator
IF YOU HAVE A 93 OR LATER CYCL HEAD, YOU WILL HAVE PINGING UNLESS YOU SET THE TIMING AT AROUND 6 DEGREES
Jerry-
You know I love you and I respect you, but I do not agree with the above.
I am running a '95 head on top of a '91 bottom end with a .040" overbore. Stock early injectors and computer, larger MAF and TB, a Delta cam and a header. Timing set at 12*, no pinging unless I am pulling a steep grade, like really STEEEEEP grade at speed. There is only one hill that does that to me around here and I have not pulled it with high grade gas yet to see if it makes a difference.
BTW, for reference, the CR cc'd out to 9.3:1. Power is great. It pushes 35's with 5.38's like a dream. Avg MPG is about 22-24 (mostly hwy) with about 2200mi on the rebuild.
Michael
Re: Does this sound logical? Little grounding strap is the root of all evil? #475898 07/15/04 03:37 PM
Durring my rebuild I discovered that the same ground strap had not been re-installed but we continued on and made note of it. When we attempted to start the truck upon completion the computer did what kevin described "went bananas". I simply went to Sanels, purchased a longer strap and found an alternate root to ground to. That solved that issue.
I also had a ping which was described to me as a timing knock. I did what JLemond suggested to you here and adjusted the timing. That problem too is solved.
Just had to put my $1.50 in cuz you are referring to the same ground strap that I dealt with and my symptoms were quite different than yours.
Hope you figure this out phil...good luck.
Re: Does this sound logical? Little grounding strap is the root of all evil? [Re: mlclark] #475899 07/16/04 04:00 AM
JLEMOND Offline
WILL AGREE WITH YOU COMPLETELY , THEY SHOULDN,T PING, BUT AT 12 DEGREES 90 DEGREE WEATHER AND REGULAR GAS IN THIS PART OF THE COUNTRY RATTLE RATTLE, MINE CHECKED OUT AT EXACTLY 9.0 ONE, HOWEVER I AM RUNNING A STOCK CAM WITH LESS OVERLAP THAN YOURS WHICH SHOULD MAKE MY CYL PRESS HIGHER , BUT AT THE SAME TIME YOU ARE RUNNING MORE LIFT TO CREAT MORE EFFECTIVE CYL PRESS, FINAL JUDGEMENT 8 DEGRESS, REG, GAS 20-22 MPG GIANT 225X15 TIRES AND A GOOD WORKING EGR SYSTEM BUT FUEL QUALITY HERE IS NOT THE BEST EITHER.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5978 MB (Peak: 0.6514 MB) Data Comp: Off Server Time: 2026-06-22 11:20:56 UTC
