Page 3 of 3 1 2 3
Re: Body Lift Questions [Re: Kookadala] #476177 07/16/04 06:06 AM
dankman Offline OP
okay, thanks all...did the bumper...looks normal now.
hitch is next...$ on the way scott...
as for the hot air...took apart the cosmetic boot/frame and noticed that the black rubber boot, when shifted to 2nd and 4th, the front of the boot bends upward...source of the hot air and noise...i forgot about flipping it over, but now i've decided the put a couple of screws to hold it down...
as for the dt lift...i searched...TOO much info...
1996 T100 4X4 on 33" BFG ATs, 2" BL, 5 spd
Re: Body Lift Questions [Re: surlynkid] #476178 07/16/04 06:41 PM
dankman Offline OP
not too hard to install. get motor mount lift from roger brown. shifters come back where they belong. radiator drop gets removed. auto trans shifter piece comes out. then you can either get a tcase lift from roger or a whole crossmember from bud. then you will have to move the carrier bearing up like brew is doing. i think that is all there is.
okay, starting to get lost...if i do above, that'd be 2" motor mount lift, 1" tranny and do the crossmember? what's exactly invoved with moving the carrier bearing?
Re: Body Lift Questions [Re: dankman] #476179 07/16/04 07:13 PM
surlynkid Offline
if you lift the carrier bearing, you can lift the tcase the full 2". if not, only 1 without getting vibes. climb under and look at the bearing in the rubber assembly which is at the middle of your rear driveshaft. that part mounts to a crossmember in the frame. youd have to notch the frame crossmember and push the carrier bearing up. you can get a 1" or 2" tcase spacer by itself from roger brown or you can get it incorporated into a whole new tcase crossmember from budbuilt which give you GOBS more clearance under the tcase.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6037 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-11-17 11:29:45 UTC
