Page 2 of 4 1 2 3 4
Re: Newbie related T100 questions [Re: surlynkid] #477889 07/20/04 05:27 PM
You cats are alright. I appreciate all the insight.
I PM'd him a day or so ago in regards to his T.
Wouldn't mind checking it out. I am in Minnesota, but have flown numerous times to get vehicles. Most recently to pick up a '98 jetta TDI. Diesel baby. Don't get me started.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Never-the-less, if you have other gotchas or what not, let me have it.
What are the recommended timing belt/water pump change intervals?
Thanks again -keir
Re: Newbie related T100 questions #477890 07/20/04 06:20 PM
surlynkid Offline
timing belt in the 60-100K range. i do the water pump at teh same time since it is only $100 and too big a PITA to dig back into it again.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Newbie related T100 questions [Re: surlynkid] #477891 07/21/04 03:26 AM
dogslovetrucks Offline
you can get brackets to drop both corbeau and recaro buckets straight into the T-100. I put a bucket into my T-100, (left the right bucket inplace because it is comfy) and it was probably the best mod I have ever done, put over 20K miles on it and love it. You do want to try to find a dealer and try on the seats before you get them because there are some differences for each seat.
Re: Newbie related T100 questions #477892 07/26/04 02:44 AM
All,
I came across a '97 SR5 located at a Ford stealership.
The particulars are such:
5spd
Topper
164k miles
and...
BUCKET
$6499
any concerns among the populus in regards to the 164k miles. Would it scare you? I think I may jump on this one, however, wanted to clear it with the experts and see what ya'll had to say. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I sincerely doubt I will be able to find out serive history(TB, water pump). So, those repairs will be in my close future.
Again, thanks in advance. I appreciate your help!
-keir
Re: Newbie related T100 questions #477893 07/26/04 03:03 AM
I just paid 4500 for a clean '95 SR5 4x4 auto, a/c, power everything, etc. It has 255K miles and runs strong on all original motor and tranny, no leaks, no issues. 165K is nothing. I sometimes think I paid too much, but seriously the only issue is the little numbers on the dash, otherwise the truck runs and looks like something that cost 10 grand.
<img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Newbie related T100 questions #477894 07/26/04 03:04 AM
uzombie Offline
Check it out.
Timing belt and water pump aren't big deal. Besides, our best source for parts is Gettel Toyota for the DIY.
Check Clutch-pedal bracket (check for crack at firewall/pedal).
Check the steering shaft boot for rot. (minor)
Go take it out for a drive and offer them $6K.
I have factory radio/cassette and Factory CD changer in a box if you need it.
<img src="/forums/images/graemlins/ignore.gif" alt="" />
Good luck! Keep us posted!
Re: Newbie related T100 questions [Re: uzombie] #477895 07/26/04 03:08 AM
I come from the honda and vw world where if you blow a timing belt, you break/bend valves. Not the case here? I hope to drive it tomorrow. I will let you know my findings!! Thanks to all. Keep that info coming.
closed circuit to UZOMBIE, weren't you just telling me to try to find a 97-98!?! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Newbie related T100 questions #477896 07/26/04 03:49 AM
surlynkid Offline
the T100 is a non-interference motor. a broken timing belt will not bend the valves. almost all of the toyotas with an interference motor get a timing chain. i believe there is an exception or two, but not the T100.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Newbie related T100 questions [Re: uzombie] #477897 07/26/04 01:44 PM
cymmgarcia Offline
Uzombie,
I have a Factory 3-in-1 that I would like to trade for a Factory AM/FM/CD setup so I can use the pocket space for my CB radio. Please let me know if your interested. Thanks.
cymmgarcia@yahoo.com
Re: Newbie related T100 questions [Re: cymmgarcia] #477898 07/27/04 04:40 AM
uzombie Offline
IT won't do you any good. The top unit is the AM/FM Cass. The Bottom unit is the CD Changer (3 disc cart). It takes up both Slots as your 3-n-1 takes them up.
And Keir- 97 is good. 98 is good. I just think of them as better than 95-96 because you can't put the TRD Supercharger on the 3.4L 95-96 motors. But they are all good motors. (TRD and Toyota Emission changes are the reason for the SC issue).
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6320 MB (Peak: 0.7393 MB) Data Comp: Off Server Time: 2026-06-23 00:43:06 UTC
