Headlights?
#478404
07/20/04 09:24 PM
My headlights on my 2000 Kia Sportage were very dim, so i figured it was my battery...i replaced the battery and still they are the same. COuld this be a fuse or do i just need new bulbs? Any Suggestions? thanks <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Headlights?
#478405
07/20/04 09:30 PM
Check for corrosion on the terminals. I have had mine go dim, and by just touching the connector they brighten right up, and after cleaning they have been good for the last 6 months. I'd also verify the condition of the ground wire behind the parking light on each side.
Re: Headlights?
[Re: kiasound]
#478406
07/21/04 01:26 AM
I would assume that the problem with the headlights and the starter / ground connections or whatever the problem with the starting system are the same problem. I bet that when you get the starter problem fixed then the headlights will be magically cured.
Re: Headlights?
[Re: tlab]
#478407
07/21/04 08:06 AM
and since grounging is a known bug of the system, I wouldnt be surprized..... Good point my friend <img src="/forums/images/graemlins/kewl.gif" alt="" />
'96 4d mechanicaly stock so far, rims, spoiler, Cooper AT tyres, Factory LSD, Manual Warn Hubs, handmade exaust, ELECTRIC FAN!!! 3,1'' Lift, PALM GPS http://members.cardomain.com/fokion
PHP: 7.4.33 Page Time: 0.479s Queries: 15 (0.004s) Memory: 0.5952 MB (Peak: 0.6529 MB) Data Comp: Off Server Time: 2026-06-23 22:28:33 UTCValid HTML 5 and Valid CSS
