Re: Old School CJ with offset differential [Re: kobyhud] #478738 07/28/04 07:00 PM
i ripped everything out. these old heeps are the worst when it comes to steering! to replace, i am using an s10 box, pump and collum...and it is all custom fab. i also got the parts from S&N fab to do a bullet proof highsteer-crossover, but the arms need to go up about 2" and i am lazy, so it is just a standard crossover for now.
Re: Old School CJ with offset differential [Re: kobyhud] #478739 07/28/04 07:17 PM
kobyhud Offline OP
Alright, Here is the current plan,
We have used stock YJ springs that we are going to set up SOA.
We have located a passenger side offset differential with 4.10 gears from a Fj40 land cruiser that we picked up for 130 bucks.
We have also located a toy mini truck front end with 4.10 gears as well.
We are going for the toy axles because we will likely use a toy CV in the driveline because Saginaw CVs dont have near the strength of a toy CV. Also we happen to be used to pulling out birfields and in general with working with these differentials. Most of our connections are in the Toyota arena anyway.
The current gear ratio is 4.3ish and the poor jeep just screams along in third gear at 65. We figure the swap to 4.10s and the addition of at least 33" tires will correct this allowing 65 to be at least a comfortable driving speed and 75-80 to be the new screaming speed.
The engine in the old beast is a chevy 29? 294 I dunno, it was recently rebuilt and has plenty of power for the tiny little jeep. This is the true saving quality for the jeep. Also the body is in great condition for being left outside so long.
As for steering we arent going to bother with histeer. Just straight crossover. WE are definently going to have to find a good steering box to replace the stock one.
I will try to post some pictures when I can.
95 Rodeo LS, Auto, SAS, , 60 front, 14 bolt rear. 5.13 r&p, Hydro-Assist, teras..
http://www.pieceofhud.com/gallery
Re: Old School CJ with offset differential [Re: kobyhud] #478740 07/30/04 07:33 AM
Saginaw? You sure you don't mean Spicer? You're also aware that there are many different sizes of both Spicer and Saginaw CV joints, right?
Anything can be adapted to anything else these days with the large aftermarket support for driveline supplies.
Re: Old School CJ with offset differential #478741 07/30/04 07:48 PM
kobyhud Offline OP
I said toy mostly because we have spares. Being as that is what we most commonly build.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6602 MB) Data Comp: Off Server Time: 2026-06-20 17:40:38 UTC
