Page 15 of 16 1 2 13 14 15 16
Re: Front Limited Slip- (Progress) [Re: DamKia] #480799 11/09/04 09:03 AM
MorganEstill Offline
Awesome. Thanks. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: Front Limited Slip- (Progress) [Re: MorganEstill] #480800 11/09/04 02:11 PM
wd8cdh Offline OP
The Pinion bearings are the same both front and rear. We just don't know if the pinion depth and hypoid offset are the same yet.
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
Re: Front Limited Slip- (Progress) [Re: wd8cdh] #480801 11/09/04 02:21 PM
Dave Scott Offline
yeah, uhhh, haven't been able to get that pinion loose yet, sorry. anyone know, off-hand, what the pinion nut size is? the one on my Dana 44's is 1-1/8" - easy with a hitch-ball socket.......
Re: Front Limited Slip- SUCCESS [Re: Dave Scott] #480802 11/30/04 07:06 PM
wd8cdh Offline OP
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> The Miata Torsen LSD is now in the front of my Sporty!!!! <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
It only took a new snap ring from the Miata dealer. No grinding etc.
The hardest part was finding the specs for the bearing preload. It's not in the factory service manual. I found it in a Miata service manual and confirmed it with a RX-7 service manual. You preload the bearings so the bearing caps spread to 7.3003" - 7.3031". I set it for 7.3030" and spun the pinion with an electric motor for about 10 minutes and then reset it for 7.3010".
Running 80W-90 GL-5 conventional oil now but will change to 75W-90 GL-5 Redline synthetic in the spring.
Pulls thru the turns in 4WD like a FWD Rally car now. <img src="/forums/images/graemlins/smile.gif" alt="" />
Very controlable in de-cell too.
No dragging in turns in 2WD even with the manual hubs locked.
I will probably put the factory LSD in the rear next year. (no money now) <img src="/forums/images/graemlins/frown.gif" alt="" />
Ron Schroeder
Long Island NY
Re: Front Limited Slip- SUCCESS [Re: wd8cdh] #480803 11/30/04 07:35 PM
shifter26 Offline
that is really great .. congrats ..
Re: Front Limited Slip- SUCCESS [Re: wd8cdh] #480804 12/01/04 08:09 AM
How much did the Torsen set you back? An LSD in the front sounds great and if the ARB deal comes through, that'll be a very nice setup. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Yeah... I'm low on the bling, too. I'm getting 31" Super Swampers pretty soon and I need steel for the custom bumpers I hope to be building with a friend's professional MIG welder... ( <img src="/forums/images/graemlins/smile.gif" alt="" /> )... so that pretty much breaks the bank... and I had to buy one of those new Nintendo DS's, so there's another $150... But it's so great!!! [Holy crap... I'm such a nerd... <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> whatever....]
Re: Front Limited Slip- SUCCESS [Re: MorganEstill] #480805 12/01/04 05:39 PM
wd8cdh Offline OP
I got the Torsen on ebay for an embarassingly low price. The seller had a miss-spelling in the title so there were few people who were able to search for it.
The going rate is $300 to $700. The snap ring was $4 at the Mazda dealer.
The weather was freezing rain today. The Sportage pulled on the straight almost as good as my AWD van and better than the van in the turns which is a very good thing since the van has new A/T tires and the Sportage tires are almost bald.
Ron Schroeder
Long Island NY
Re: Front Limited Slip- SUCCESS [Re: wd8cdh] #480806 12/01/04 05:44 PM
Ron,
Do you know what year that came out of? I have called several yards. They tell me the 94 and 95 are the same, 96 and 97 are the same,98+. It may be the difference in the T1 and T2
Keith
Re: Front Limited Slip- SUCCESS #480807 12/01/04 07:20 PM
Hey - which Torsen, the T1 or T2, did we decide was best for offroading? Can't find it using search... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Front Limited Slip- (Progress) [Re: MorganEstill] #480808 12/01/04 07:37 PM
maraguez Offline
I got to get one of those... What year Miata did you get?
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6477 MB (Peak: 0.7562 MB) Data Comp: Off Server Time: 2026-06-10 07:27:30 UTC
