Page 16 of 16 1 2 … 14 15 16
Re: Front Limited Slip- (Progress) [Re: maraguez] #480809 12/01/04 07:42 PM
Axe Man Offline
Kia Moderator Emeritus
Does anyone else see a rash of Mazda Miatas up on blocks missing their rear diffs? <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Front Limited Slip- (Progress) [Re: Axe Man] #480810 12/01/04 08:14 PM
I just found one at a Mazda Salvage yard. $900 big ones. I'll keep searching. I would like to know which year the T1 came in and what year Ron's is. The guy at mazda told me that the 94/95 and the 96/97 would fit but he did not know the difference. The one above is for a 2001. Might be the reason for the high price. He was at Mazmart in Atlanta and said that it was 26 spline and should work. He said the 93 and older had the vicous ?sp.
Re: Front Limited Slip- SUCCESS [Re: MorganEstill] #480811 12/01/04 08:51 PM
wd8cdh Offline OP
Hi Keith and Morgan,
I think it is for a '94. It is a T-1. I think the T-2 came out mid '95. The T-2 might be SLIGHTLY stronger but the T-1 is SLIGHTLY more agressive. Any '94 and newer Miata diff. should fit. There is also a RX-7 clutch type LSD that will also fit. It was in some of the non-turbo models.
The '93 and older Miata had a much smaller diff (6" ring gear) and will NOT fit.
Unfortunatly, most Miatas have an open diff, not the Torsen LSD.
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
Re: Front Limited Slip- (Progress) [Re: Axe Man] #480812 12/02/04 06:45 AM
MorganEstill Offline
Boy, I sure hope so... Then I could actually get a Torsen... <img src="/forums/images/graemlins/shiner.gif" alt="" />
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: Front Limited Slip- SUCCESS [Re: wd8cdh] #480813 12/02/04 06:59 AM
Is this for sure? From pictures I've seen of the RX-7, it looks a little bit different... of course the T-1 for the RX-7 operates like the T-1 for the Miata - Helical gear system - not clutch (at least this one.).
Miata Torsen (T-1):
RX-7 Torsen (T-1, also):
<img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Rx-7 Turbo diff will not fit. [Re: MorganEstill] #480814 12/02/04 01:53 PM
wd8cdh Offline OP
Hi Morgan,
The lower picture looks like a Torsen from a RX-7 Turbo model. None of the RX-7 Turbo diffs will fit the Sportage. They are 8" ring gear, different splines etc.
Ron Schroeder
Long Island NY
Miata Torsen on ebay [Re: wd8cdh] #480815 12/02/04 09:55 PM
wd8cdh Offline OP
Ron Schroeder
Long Island NY
Re: Miata Torsen on ebay [Re: wd8cdh] #480816 12/03/04 07:07 PM
Yeah, I know that's where I got my picture. I want that LSD... Too bad I need new tires...
On the bright side, though, I finished my light bar for the Sportage. Looks good. I'll have to post some pics when I get it on my vehicle.
Re: Snap ring for Torsen [Re: MorganEstill] #480817 12/08/04 03:10 PM
wd8cdh Offline OP
The snap ring that I used for the Torsen conversion was Mazda M005-27-421.
Ron Schroeder
Long Island NY
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6406 MB (Peak: 0.7609 MB) Data Comp: Off Server Time: 2026-11-16 21:07:28 UTC
