Re: alternator holding at 11.60.... [Re: Spacetrucking] #481138 07/29/04 05:47 PM
indy Offline
It's very bad to let a battery just sit for long periods
of time. The plates inside may be shorting from corrosion.
It's best to put a low amp trickle charger on them for
extended sitting or at least put a regular charger on
them every 2-3 weeks to keep them from discharging to the
point of causing damage. I've heard that the solar
trickle chargers work well for keeping batteries up that
aren't used very much if you want something that's
'hands off' for the winter.
Regards,
Indy
Re: alternator holding at 11.60.... [Re: indy] #481139 07/29/04 05:54 PM
SHAD Offline
Hunter, I have a old spare genuine 65 Amp nippon denso alternator that needs new brushes if you want it. It came out of my 4 runner after I did the GM CS130 105 Amp alternator swap.
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: alternator holding at 11.60.... [Re: hunterp] #481140 07/29/04 06:45 PM
Don't forget the Mobi-Arc upgrade...
http://www.4x4wire.com/toyota/tech/alternator/
Re: alternator holding at 11.60.... [Re: indy] #481141 07/30/04 12:25 AM
Spacetrucking Offline
Well, it's not the battery. Just put a better new one in and I'm getting an electrical shorted burning smell from the coil area. Didn't have time to delve into it, had thhe luxurt of leaving it off at a local mech. in the industrial complex where I work. I'll let you all know what he found comes Monday. BTW I just had a motor swap done over the winter so something may be up. ( good used 22R that went to 22RE with my EFI )
'86 SR-5 Extra-cab 4 x 4, 2" BL, 33 x 12.5 x 15R M/T on 15 x 8 rockcrawlers ( 3 3/4" BS ), 22RE 5 sp , 4.88's Detroit True-Trac front, V6 open rear, 24 mm Sway-Away + Rancho 5000's, removed sway bar, no-rust south US bed, Ramsey 8000 winch
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6033 MB (Peak: 0.6614 MB) Data Comp: Off Server Time: 2026-11-16 01:23:49 UTC
