Stupid Q - '85 Toyota battery ground cable #483257 08/02/04 06:52 AM
NVR FNSH Offline OP
I'm replacing the battery cables in my '85 22RE (they are the originals) and I'm wondering if anybody has found a good place to run another ground cable. The stock ground cable attaches to the inner fender panel and I'd like to run a second ground cable to the engine or frame - I'm just lazy and hoping somebody can tell me what length cable and where to attach it.
Brian
Re: Stupid Q - '85 Toyota battery ground cable [Re: NVR FNSH] #483258 08/02/04 07:29 AM
stock87 Offline
When I did my ground cables, I ran some 4 Gauge wire from the fender ground to the frame, between the battery and the headlight, and down to a pre-threaded hole at the front of the frame. I did the head -> body ground with 4 ga. as well. I added some others too, but at the moment I can't remember where <img src="/forums/images/graemlins/confused.gif" alt="" />. No real performance difference, but the volt meter seems to register a bit higher now. Couldn't have hurt, might have helped.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Stupid Q - '85 Toyota battery ground cable [Re: stock87] #483259 08/02/04 07:42 AM
dewmtndew Offline
Hmmmmm, your makin me think about throwin a couple extra ground wires under my hood.... <img src="/forums/images/graemlins/coolg.gif" alt="" />
erick
85 Pickup
33s, lift, EB cam, header, exhaust...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5903 MB (Peak: 0.6439 MB) Data Comp: Off Server Time: 2026-06-13 11:22:25 UTC
