Rear ceneter bearing #483307 08/02/04 02:51 PM
urso8up Offline OP
On my 98 T100 the rear drive shaft center bearing. How do you kow if it needs replacing? I have a annoying sqeak and i was wonding if it was from that
1998 T100 4x4 3 body lift 4 procomp suspension 15x10 steel wheels and 35x12.50x15 Baja Claws
http://www.cardomain.com/id/urso8up
Re: Rear ceneter bearing [Re: urso8up] #483308 08/03/04 06:28 PM
urso8up Offline OP
anyone???
Re: Rear ceneter bearing [Re: urso8up] #483309 08/03/04 07:18 PM
garym Offline
You didn't say why you think it is the bearing. Is the noise there constantly? The most common source of a squeak is the hood latch mechanism. It usually makes noise going over bumps but is hard to isolate. Try cleaning it off or hitting it with some Tri-Flo or something to see if that takes care of it.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Rear ceneter bearing [Re: garym] #483310 08/04/04 01:04 PM
urso8up Offline OP
It is not a sqeak like it is more like a sqeal or metal griding. It only happens in reverse and tha tis all that is why i can not find it and was hoping for some help
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6002 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-06-05 07:31:09 UTC
