Most Durable Stock Setup? #483316 08/02/04 04:38 PM
javven Offline OP
What's the most durable stock setup (Year, engine, tranny) from Toyota? What are the top 3? Any 'worst'? I never figured toyota made anything weak on their 4WD's but I could be wrong. Include everything but LandCruiser..
Looking for a 4WD SUV (or pickup) and have been burned by transmission/driveline issues before and do not want to be so again...
Change your oil hot and often.
07 Taco V6 4WD 5-Auto
Re: Most Durable Stock Setup? [Re: javven] #483317 08/02/04 04:42 PM
little_joe Offline
Former Admin
I have to ask - for what purpose and preferences? Daily driving? hardcore wheeling? higher onroad speeds or comfort touring? carrying loads / work truck?
It does matter, since the suspensions over the years are (obviously) quite different and perform differently.
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Most Durable Stock Setup? [Re: little_joe] #483318 08/02/04 05:05 PM
javven Offline OP
Understood. I'm more concerned about the drivetrain than anything else. Longevity (into the 300K range) a plus. Suspension's always nice to have bulletproof but honestly I've never been one to haul heavy loads with the vehicle.
Concerns would be off-roading (I'm the slow, methodical type who'll sit for a minute figuring out an obstacle rather than blasting through it), trailering (3000lbs or less) and general reliability.
Re: Most Durable Stock Setup? [Re: javven] #483319 08/02/04 05:59 PM
mt_goat Offline
Well except for the head gasket problem, I can't image a much stonger stock set-up than the V6, 3rd gen pick-ups (89-94.5 I think). The newer tacos have the weaker rack and pinion steering and the frame is not fully boxed. The older 4 cyl trucks have a little weaker differental and gears but they did have a solid axle up front for a big plus there.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: Most Durable Stock Setup? [Re: javven] #483320 08/02/04 06:04 PM
mt_goat Offline
If you were to allow us a non-stock option I'd take the newer 98-2000+ 3.4L engine, the 3rd gen truck with an SAS. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Most Durable Stock Setup? [Re: mt_goat] #483321 08/02/04 06:26 PM
A
averkam Offline
I do not know if this the "best" that Toyota has ever built but it sounds like exactly what you need. I have towed 3000+ # at highway speeds (75mph) for 2+ hours at 4,000 RPM and the truck has not missed a beat. Short of the standard Toyota driveline issues (rear axle seals leaking, carrier bearing wearing out, burt exhaust valves) I would say that this set-up is bullet-proof.
2000 Ext Cab SR5 4WD 2.7L 5-speed.
Re: Most Durable Stock Setup? [Re: averkam] #483322 08/02/04 06:46 PM
javven Offline OP
Current candidate is a 1994 5-sp 4-cyl. I guess this would have been the 22RE at the time...
I'm looking for the fewest hassles down the road and the lowest repair costs should they be needed. I'd also like to add the twin-stick setup from Marlin at some point but that's later down the road - if ever.
I have always liked a V6 for power but I'm not sure it's necessary for what I'm looking to do. I haven't towed a trailer in years and wouldn't do it frequently but I -would- like to have the capability to do it. Nothing more than a smallish boat or small h-hell trailer.
Re: Most Durable Stock Setup? [Re: javven] #483323 08/02/04 07:00 PM
Esquire812 Offline
22R-E equipped rig with a 5speed transmission is calling your name. Okay, so maybe not calling it clearly...but I swear thats what Im hearing. The 22R-E can be modified relatively on the cheap, fixed without breaking the bank and can pull a trailer holding an 18' Alumaweld no problem. While it wont win any races while towing, it will get you there without looking like an idiot doing 25mph in 50 mph zone. <img src="/forums/images/graemlins/smile.gif" alt="" /> I do it from time to time around here...lots of hills.
Problem is finding a 5 speed 4Runner from that generation. Autocrackaddict transmissions coupled to 22R-Es leave alot to be desired.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Most Durable Stock Setup? [Re: javven] #483324 08/02/04 07:04 PM
Kaptain Offline
The 22re will be alot easier and cheaper to work on if you happen to have any problems. Even a basic tune-up will be much easier and cheaper on the 4cyl. On top of that you'll be getting better gas mileage (20 - 25mpg). You wont have any problems hauling a small trailer either.
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: Most Durable Stock Setup? [Re: Esquire812] #483325 08/02/04 07:23 PM
javven Offline OP
Downsides to buying here:
Everything's auto.
Mostly V6 (not bad, just not a lot of choice).
SUV's = way overpriced.
Everything has a bizillion friggin miles.
Upsides:
Almost none of these rigs have seen anything other than pavement.
Very little modifications to the 4WD's. Aftermarket mods are fine in some cases, but most of the time citified-mods just blow hunks.
Good washing/exterior care.
Rust? Not here.
Mostly they're not used for towing rigs. Most of the urbanites here have big american SUV's if they tow anything bigger than a bike rack.
Anyhow... yeah, I've always been a 22r fan but I'm certainly willing to listen to any other recommendations.
PHP: 7.4.33 Page Time: 3.268s Queries: 16 (0.003s) Memory: 0.6394 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-06-20 22:21:43 UTC
