When to change lower plenum, valve seal guide on 95 SR #483812 08/03/04 07:47 PM
I have a 95 SR with 123K miles. I have been reading defects in this forum for the 3.5 dohc engine specifically the lower intake plenum and valve seal guides. With the said mileage, do I need to have them replaced now? What is the problem with the factory lower intake plenum?
Thanks.
Re: When to change lower plenum, valve seal guide on 95 SR #483813 08/04/04 01:16 AM
There is a lot of good information in this forum on that subject. Do a search of the archives and check out the project page. There is a detailed article with pics on what is entailed. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: When to change lower plenum, valve seal guide on 95 SR #483814 08/05/04 03:05 PM
Thanks otall1. I did do a search and still can't find a reason why the lower intake plenum should be replaced at Monty's age. I will be replacing plugs, wires, coils(still contemplating), fuel filter, and perhaps the plenum if I find a good reason for it.
Re: When to change lower plenum, valve seal guide on 95 SR #483815 08/05/04 05:55 PM
davemtb Offline
The reason to change the lower plenum is so you don't ingest the butterfly rod bushings into your valves. If you are doing the plugs & wires, you are already removing the old plenum, so it would be little additional work. The process to test you variable intake valve is described in detail in several posts on the subject, and is pretty simple. It involves removing a vacuum line and listening for a sound to stop. The updated part number is also available in older posts. I would at least check the part number while you have the intake off.
That being said, I also own a '96SR, and my truck already had the updated lower plenum. Not sure if that came from the factory, or if the previous owner had it changed.
Good luck.
Dave in KC
Dave Smith
'96 SR - 31x10.5 Tires
"Facts are meaningless. You could use facts to prove anything that's even remotely true!" Homer Simpson
Re: When to change lower plenum, valve seal guide on 95 SR [Re: davemtb] #483816 08/06/04 06:57 PM
Thanks to all your replies. How do I tell now If I have an updated plenum or not, so I could decide if it is necessary to replace it? Sorry being such a pest.
Re: When to change lower plenum, valve seal guide on 95 SR #483817 08/06/04 08:38 PM
davemtb Offline
The updated part number is MD335940. This part number is cast into the new plenum.
I have a new in the box updated plenum if you are interested in buying it.
Dave
Dave Smith
Re: When to change lower plenum, valve seal guide on 95 SR [Re: davemtb] #483818 08/09/04 06:01 AM
If you have a 95, you have the faulty plenum, unless it's been replaced for some reason. My truck has 135k on it and the plenum is shot, (but that's because I destroyed the bushings with diesel fuel when I replaced the stem seals-accidentally forgot it was in the cleaning bin). The bushings were still in great shape prior to that.
Dave
How much are you asking for the plenum?
Re: When to change lower plenum, valve seal guide on 95 SR #483819 08/09/04 04:31 PM
If the 95 SR has a faulty factory plenum, was a recall ever made?
Re: When to change lower plenum, valve seal guide on 95 SR #483820 08/09/04 11:49 PM
unfortunately they didn't feel they should pay for it so they never recalled it. Pretty lame if you ask me, I think this is one of the things on the long list of why Mitsubishi is having to do serious restructuring to try and stay in business
Re: When to change lower plenum, valve seal guide on 95 SR #483821 08/10/04 02:53 PM
If we can prove this defect to Mitsu, we probably can file a class action lawsuit. The updated plenum and cost of labor to replace it is very costly.
Any lawyer here?
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.012s) Memory: 0.6201 MB (Peak: 0.7256 MB) Data Comp: Off Server Time: 2026-11-20 03:08:09 UTC
