Re: one small mod with some results
[Re: MorganEstill]
#484686
11/06/04 01:13 PM
Somebody @ CarDomain. Fom times to times I check the Sportages listed there...
#484687
11/06/04 11:48 PM
Check this out: Notice the extra battery carrier. That's very cool. Where can I get one of those?
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...  "What is IFS and where can I get some??" (outerlimits4x4.com)
[Re: MorganEstill]
#484688
11/07/04 01:08 AM
That's not extra batery, I guess the right driver sportages comes with the battery on the left side. Gary, can you confirm that?
#484689
11/07/04 06:39 AM
Kia Moderator Emeritus
That's not extra batery, I guess the right driver sportages comes with the battery on the left side. Gary, can you confirm that? Correct, that's a right hand drive Sportage.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: Axe Man]
#484690
11/07/04 07:39 AM
Kia Moderator
That's right, we have the battery right above the exhaust manifold. What a wonderful piece of engineering that is, normal battery life 2-3 years in a generally temperate weather area..... <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: Axe Man]
#484691
11/08/04 02:42 AM
That's not extra batery, I guess the right driver sportages comes with the battery on the left side. Gary, can you confirm that? Correct, that's a right hand drive Sportage. Either way, I don't have anything over on that side and if I could some how get my hands on one of the brackets for the right-hand drive, I could add another battery (I'm gonna need one with all the lights that're going on it - 3x130W lights on front bumper, 2x55W fog lights, 4x55W lights on custom light bar (on roof), just finished (gotta mount it), 2x55W rear aux. (on safari rack), 2x55 rear aux. (in upcoming custom rear bumper).
[Re: MorganEstill]
#484692
11/08/04 08:25 AM
Kia Moderator
That's not extra batery, I guess the right driver sportages comes with the battery on the left side. Gary, can you confirm that? Correct, that's a right hand drive Sportage. Either way, I don't have anything over on that side and if I could some how get my hands on one of the brackets for the right-hand drive, I could add another battery (I'm gonna need one with all the lights that're going on it - 3x130W lights on front bumper, 2x55W fog lights, 4x55W lights on custom light bar (on roof), just finished (gotta mount it), 2x55W rear aux. (on safari rack), 2x55 rear aux. (in upcoming custom rear bumper). You don't need another battery, but you do need an uprated alternator. If you have just the fwd facing lights on(4 x roof 55w + 3 x bullbar 130 w + standard tail lamps + 2 x 65w standard headlamps) + the current needed to run the engine (EFI/Ignition), you will need about 90 amps continuous out of your alternator, we only have a 70 amp alternator at peak revs.... Idle the car (< 2500 rpm) for anymore than 30-40 minutes a night and you wont be able to start it up again. Idle it for more than 1 hour and it will stall due to flat battery. BTW, these figures assume that you ARE staring with fully charges batteries.... Having two batteries will lengthen the time you have until your batteries go flat, but they will still go flat. It is a supply/demand issue and you are trying to tackle the wrong end., The battery is simply a reservoir to capture excess alternator charge, and in your case you don't have any.....
[Re: DamKia]
#484693
11/08/04 08:29 AM
..... plus when you eventualy flat the batteries it will take ages to recharge by the altenator
'96 4d mechanicaly stock so far, rims, spoiler, Cooper AT tyres, Factory LSD, Manual Warn Hubs, handmade exaust, ELECTRIC FAN!!! 3,1'' Lift, PALM GPS http://members.cardomain.com/fokion
[Re: fokion]
#484694
11/08/04 02:03 PM
What Gary and Fokion are saying is very true. The Alternator needs to exceed the load condition but the battery only needs to start the engine and run the lights(or listen to the tunes) with the engine off.
In fact, I ran my Sportage for a couple of months with only a 5AH battery.
Ron Schroeder Long Island NY 99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD 00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress 73 Pinzgauer Swiss Army troop carrier
[Re: wd8cdh]
#484695
11/08/04 02:48 PM
But obviusly your consumption is LESS that the alten. production
