Page 6 of 6 1 2 3 4 5 6
Re: one small mod with some results [Re: fokion] #484696 11/08/04 05:45 PM
wd8cdh Offline
Of course, I was only running 4 extra halogen lights.
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
Re: one small mod with some results [Re: DamKia] #484697 11/08/04 07:23 PM
MorganEstill Offline
You don't need another battery, but you do need an uprated alternator. If you have just the fwd facing lights on(4 x roof 55w + 3 x bullbar 130 w + standard tail lamps + 2 x 65w standard headlamps) + the current needed to run the engine (EFI/Ignition), you will need about 90 amps continuous out of your alternator, we only have a 70 amp alternator at peak revs.... Idle the car (< 2500 rpm) for anymore than 30-40 minutes a night and you wont be able to start it up again. Idle it for more than 1 hour and it will stall due to flat battery. BTW, these figures assume that you ARE staring with fully charges batteries....
Having two batteries will lengthen the time you have until your batteries go flat, but they will still go flat. It is a supply/demand issue and you are trying to tackle the wrong end., The battery is simply a reservoir to capture excess alternator charge, and in your case you don't have any.....
Yeah... I don't think I'm gonna be running all them lights at once... I plan on using only the 3x130W up front or only the 4x55W on top at a time. Besides, you only really need one set at a time. Like with the foglights, you're NOT gonna need to have the 130Ws on.
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: one small mod with some results [Re: DamKia] #484698 11/08/04 07:23 PM
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6069 MB (Peak: 0.6614 MB) Data Comp: Off Server Time: 2026-05-29 22:15:59 UTC
