Page 5 of 6 1 2 3 4 5 6
Re: one small mod with some results [Re: MorganEstill] #484686 11/06/04 01:13 PM
Somebody @ CarDomain. Fom times to times I check the Sportages listed there...
Re: one small mod with some results #484687 11/06/04 11:48 PM
MorganEstill Offline
Check this out:
Notice the extra battery carrier. That's very cool. Where can I get one of those?
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: one small mod with some results [Re: MorganEstill] #484688 11/07/04 01:08 AM
That's not extra batery, I guess the right driver sportages comes with the battery on the left side. Gary, can you confirm that?
Re: one small mod with some results #484689 11/07/04 06:39 AM
Axe Man Offline
Kia Moderator Emeritus
Correct, that's a right hand drive Sportage.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: one small mod with some results [Re: Axe Man] #484690 11/07/04 07:39 AM
DamKia Offline
Kia Moderator
That's right, we have the battery right above the exhaust manifold. What a wonderful piece of engineering that is, normal battery life 2-3 years in a generally temperate weather area..... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: one small mod with some results [Re: Axe Man] #484691 11/08/04 02:42 AM
Either way, I don't have anything over on that side and if I could some how get my hands on one of the brackets for the right-hand drive, I could add another battery (I'm gonna need one with all the lights that're going on it - 3x130W lights on front bumper, 2x55W fog lights, 4x55W lights on custom light bar (on roof), just finished (gotta mount it), 2x55W rear aux. (on safari rack), 2x55 rear aux. (in upcoming custom rear bumper).
Re: one small mod with some results [Re: MorganEstill] #484692 11/08/04 08:25 AM
DamKia Offline
Kia Moderator
You don't need another battery, but you do need an uprated alternator. If you have just the fwd facing lights on(4 x roof 55w + 3 x bullbar 130 w + standard tail lamps + 2 x 65w standard headlamps) + the current needed to run the engine (EFI/Ignition), you will need about 90 amps continuous out of your alternator, we only have a 70 amp alternator at peak revs.... Idle the car (< 2500 rpm) for anymore than 30-40 minutes a night and you wont be able to start it up again. Idle it for more than 1 hour and it will stall due to flat battery. BTW, these figures assume that you ARE staring with fully charges batteries....
Having two batteries will lengthen the time you have until your batteries go flat, but they will still go flat. It is a supply/demand issue and you are trying to tackle the wrong end., The battery is simply a reservoir to capture excess alternator charge, and in your case you don't have any.....
Re: one small mod with some results [Re: DamKia] #484693 11/08/04 08:29 AM
fokion Offline OP
..... plus when you eventualy flat the batteries it will take ages to recharge by the altenator
Re: one small mod with some results [Re: fokion] #484694 11/08/04 02:03 PM
wd8cdh Offline
What Gary and Fokion are saying is very true. The Alternator needs to exceed the load condition but the battery only needs to start the engine and run the lights(or listen to the tunes) with the engine off.
In fact, I ran my Sportage for a couple of months with only a 5AH battery.
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
Re: one small mod with some results [Re: wd8cdh] #484695 11/08/04 02:48 PM
fokion Offline OP
But obviusly your consumption is LESS that the alten. production
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6380 MB (Peak: 0.7626 MB) Data Comp: Off Server Time: 2026-06-04 16:14:14 UTC
