help on reading engine codes #485290 08/06/04 05:28 PM
StreetbikeDepot Offline OP
Can someone post instructions for reading trouble codes? My check engine light comes on after the motor warms up, but only at idle, if I barely tap the throttle with my foot it goes away. I've checked and adjusted the TPS several times, and it still does it. Maybe its something else?
Re: help on reading engine codes [Re: StreetbikeDepot] #485291 08/06/04 05:35 PM
Vic Lee Offline
1990 Montero 2dr 3.0 Auto Lsd Front & Rear
Re: help on reading engine codes [Re: Vic Lee] #485292 08/06/04 05:57 PM
Easy enough, found the plug, hooked up, turned on the key and not anything happened. I'm using a bulb indicator, instead of a voltmeter, same theory, light blinks when code is sent. Anyway....nothing, any ideas?
Re: help on reading engine codes [Re: StreetbikeDepot] #485293 08/06/04 07:12 PM
DaphneD Offline
Make sure the key is on the "on" position and not "accessory". If connected correctly, the computer will always spit out something. If it's normal, you'll just see a continually blinking light. Check your connection again.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5998 MB (Peak: 0.6554 MB) Data Comp: Off Server Time: 2026-06-11 23:32:01 UTC
