Ball Joint Spacer Install Complete
#485516
08/07/04 05:42 AM
Well started on installing my 1.5 balljoint spacers today. Finished with the grinding, however I can't seem to gain enough clearance between the upper control arm and the balljoint to slip it back in with the spacer on top. Not anything like the clearance shown on this page http://www.amug.org/~sschaefer/san_diego_off_road_solutions_.htmlHow do I do this? Thanks
1992 4Runner V6 SR5 4x4 Auto -ARBequed, Geared, Lifted, Lighted, and Locked. 32 BFG KM's
Re: Help!!! Ball Joint Spacer Install
[Re: SWORDFISH92]
#485517
08/07/04 06:25 AM
Try taking the nut off the top of your shock and the nut off the bottom of your sway bar end link and let everything drop down a little bit with a jack until it all slides in.
[color:"blue"]Carey[/color][b] [b][color:"red"]89 SR5 Extended Cab 4X4 V6 [/color][color:"blue"]Don't forget to pay your taxes......
Millions of illegal aliens are depending on you!!![/color]
[Re: SWORDFISH92]
#485518
08/07/04 07:20 AM
Did you remove the tension on the torsion bars?
[Re: code33]
#485519
08/07/04 06:12 PM
No, how would i do that? I have already knocked out the original studs, so i was thinking about putting the new ones in, and putting the tires back on the truck. then placing something between the upper control arm and the bumpstop. Hows that sound? Anything better/easier?
[Re: Myredyota]
#485520
08/07/04 06:28 PM
Try taking the nut off the top of your shock and the nut off the bottom of your sway bar end link and let everything drop down a little bit with a jack until it all slides in. Yep, this is what I did. I also stuffed some scrap steel tubing between the upper A-arms and their bumpstops so that they wouldn't droop so much when I jacked the rig up. With the shocks disconnected at the top, and the upper A-arms wedged so they don't drop, the lower arms should drop more than enough.
Jason '88 Toyota, flatbed junker, Inchworm dual cases, spooled rear.
[Re: BeaterToyota]
#485521
08/07/04 07:07 PM
thanks alot, I'll let you know how it goes.
[Re: SWORDFISH92]
#485522
08/07/04 11:50 PM
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
[Re: SWORDFISH92]
#485523
08/08/04 03:26 AM
well I used a bottle jack to spread the upper control arms from the lower, slid the spacers in. Finise
[Re: SWORDFISH92]
#485524
08/08/04 03:28 AM
Everyone, thank you for all your help. Made this job so much easier. Thanks again, Matt <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: SWORDFISH92]
#485525
08/08/04 03:36 AM
Oh and for reference: 32x11.50 BFG Muds on stock backspaced wheels (4.5) DO clear, but just barely. I will have to let ya'll know after I get it aligned.
