Trailer wiring
#485713
08/08/04 04:11 AM
Before I tear into the wiring for a trailer plug, I thought I'd ask you guys first. Which side do I tap into where the wires are? Do I need to get behind the tail lights? Your help is appreciated! Greg Edit: DOH!! Its a 91 4Runner.(I guess that would help)
91 4Runner V6 Auto 4x4 Performance Products progressive rear springs, Doetsch Tech MV 12 shocks, Rancho 9000 front shocks.
Re: Trailer wiring
[Re: greg_mgm]
#485714
08/08/04 04:17 AM
What year rig? On my 88 4Runner, I have a trailer light adapter spliced into the driver's side right behind the removable compartment cover where the windshield washer fluid reservoir is. That is where the previous owner put it. Here's a pic
Re: Trailer wiring
[Re: Adam F]
#485715
08/08/04 04:21 AM
Well, I'm not sure if that will help or not since yours is a 91 <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Trailer wiring
[Re: Adam F]
#485716
08/08/04 04:26 AM
Adam, thanks for the info!! I checked the back where your wires are, and bummer- not the same. I'll keep looking into this before splicing any wires. Thanks again.
Re: Trailer wiring
[Re: greg_mgm]
#485717
08/09/04 02:03 AM
A good auto parts store (I got mine at WallMart) will have a "kit" that is tottaly plug and play to hook up your trailer lights...... very easy
I need a Thneed
Re: Trailer wiring
[Re: Kyron]
#485718
08/09/04 02:20 AM
There's no plug to plug and pray.(At least not on the 2nd gens) In the back, I see split looms, but no plug. Pretty sure I have to cut into the wires, but just not sure which ones. Thanks for the reply.
Re: Trailer wiring
[Re: greg_mgm]
#485719
08/09/04 02:27 AM
i think the plug and play he is talking about plug into the rear lamps some how. I never have used them but heard of them. Get a test light and trace the wires from your tail lights if you just want to splice them.
Kevin
Re: Trailer wiring
[Re: RockJock]
#485720
08/11/04 03:10 AM
Since trailer ligths are mostly 1 lamp per side you need an adapter to make from driving ligths and diferent turn light and brakes to the american system of just the one bulb...
