Page 2 of 3 1 2 3
Re: Intake and an airbox Mod I havent seen yet. #486178 08/13/04 03:17 PM
Red_Chili Offline
Toyota Section Staffer
the junctions are 2.75" to 3" hump hose adapters (these get heavy use in large diesel engines) designed to move when the engine twists. I thought thay where a nice addition since just about every home grown intake I have seen so far uses 3" radiator hose with some sort of bushing. I will probably switch the one connected to the AFM to radiator hose when I put a larger AFM in with a 3" OD inlet.
And here I was, thinking you got them from the sewer drain section of Home Depot. Floating unions for drain pipe. Looks exactly like them. They might be vulnerable to fuel, but there should not be fuel at that point. Easily replaceable if they are.
I'm thinking this approach would be far superior to over $200 (!) for an Injen intake or whatever, for my 3.4 swap. I hate relying on K&N (or equivalent) filters, but a foam sock over the outside as a prefilter should be adequate, with an airbox built where the battery used to be.
-Bill
Re: Intake and an airbox Mod I havent seen yet. [Re: Ganoid] #486179 08/14/04 12:47 AM
Let me say, "That's a great looking truck!"
I run a 3" Dia. pipe for my intake, also I drilled 1/2'' holes all throughout my airbox and I got rid of the resonator! It made quite a diff. Believe me or not! <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/mrt.gif" alt="" /> <img src="/forums/images/graemlins/mrt.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Intake and an airbox Mod I havent seen yet. #486180 08/14/04 01:30 AM
OOP'S Offline
What made the difference, the 3" pipe, the 1/2" holes. I know it was not the resonator, all that gives you is more noise and it makes you think you are going faster, just like a loud muffler!!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Intake and an airbox Mod I havent seen yet. [Re: OOP'S] #486181 08/14/04 01:34 AM
Like I said: "Believe me or not!" One way or the other I don't give a f***! <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/rodent.gif" alt="" /> <img src="/forums/images/graemlins/rodent.gif" alt="" /> <img src="/forums/images/graemlins/rodent.gif" alt="" />
Re: Intake and an airbox Mod I havent seen yet. #486182 08/14/04 01:50 AM
Toy4x Offline
Do you give an F enough to explain why it works, or are you just an <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> ?
Re: Intake and an airbox Mod I havent seen yet. [Re: Toy4x] #486183 08/14/04 02:03 AM
I'm an <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" />!!!!!
With the 3.0, it is a very restrictive intake & exh., by doing the swap on the intake, the air flows more freely w/o going into a resonator...! The more the freeflow is, the greater the HP and the better the engine breathes...! "No sharp corners,bends..!" Freeflowing >>>>!
"Believe me or not, I don't care!"
Re: Intake and an airbox Mod I havent seen yet. #486184 08/14/04 02:08 AM
jroc Offline
[quote
"Believe me or not, I don't care!" [/quote]
Oh no, drinkin again?
Re: Intake and an airbox Mod I havent seen yet. [Re: jroc] #486185 08/14/04 02:16 AM
[quote
Oh no, drinkin again? [/quote]
NO,I've been in rehab for awhile now, I've been pretty good!
I've haven't had a drink since the last time I talked to you! "Believe it or not!" It isn't easy I will tell you that! It takes all my willpower JROC! If I offended anyone, I'm sorry! But, I'm pretty good! I'm chilled! <img src="/forums/images/graemlins/ignore.gif" alt="" />
Sorry!
Re: Intake and an airbox Mod I havent seen yet. #486186 08/14/04 02:30 AM
Toy4x Offline
I regress, the discussion was with the resonator, not all the other stuff you mentioned. I have to agree with opps, how does the resonator alone affect airflow?
If your sayin its a 'all and done / all inclusive' mod, then we're beatin a dead horse.
Re: Intake and an airbox Mod I havent seen yet. [Re: Toy4x] #486187 08/14/04 02:43 AM
The more airflow you get to the engine, (especially on the 3.0!) The more she'll put out! Agree w/whoever, it makes a diff., run that old restrictive air intake! <img src="/forums/images/graemlins/rodent.gif" alt="" />
What if I told you that modifying the air intake would give you more HP's? Knowing you, you wouldn't believe it! You must be from Missouri - (The Show me state")
Again, if the air is unrestricted, then, what is the outcome?
Almost like exh., what if I have a 2 1/4" vs. a 1/3/4" which one will breathe better? Don't be afraid to say it if you know the answer!!!~!! That's right, the 2 1/4" Exh! <img src="/forums/images/graemlins/nana.gif" alt="" />
That's too bad!! <img src="/forums/images/graemlins/ignore.gif" alt="" />
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6349 MB (Peak: 0.7432 MB) Data Comp: Off Server Time: 2026-05-30 02:10:04 UTC
