265/75's #487217 08/11/04 12:12 AM
Just picked up a new '04 regular cab 4x4 and the mod bug has already bitten. I'm looking for new, more aggressive than stock tires. I have a manual tranny with 4.30 gears. Do you think my truck could handle 265/75's powerwise with just the 2.7 and 4.30's? The specific tire I was looking at was the Dunlop Radial Rover r/t. This tire runs a tad small at 31.5 inches. How bad would the rubbing be on the stock suspension?
Thanks
Re: 265/75's #487218 08/11/04 12:21 AM
BeaterToyota Offline
I'm not too sure about the fitment issue, but there shouldn't be too much trouble with power loss. My '88 22RE has about 180,000 miles on it with stock 4.10:1 ring and pinions and isn't too bad with 32" Swampers (just a tad taller than the tires you're considering).
Jason
'88 Toyota, flatbed junker, Inchworm dual cases, spooled rear.
Re: 265/75's #487219 08/11/04 01:00 AM
little_joe Offline
Former Admin
How'd you get the 4.30 gears? auto transmission? I just bought an '04 regular cab 4x4 5-spd and it has the 3.91 gears.
BTW 265/75R16 will fit with no issues at all, *from what I've read*. I will be installing some 265/75R16 AT's before winter, these BFG's are completely useless - but hey, they're round! <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: 265/75's [Re: little_joe] #487220 08/11/04 01:19 AM
I have a manual and it came with the 265/70 tires. The door code says b07a. I got conflicting info from posts on different boards that said I had 4.30's, 4.10's or 3.91's. I finally jacked up the rear, spun the tire and counted the driveshaft rotations and came up with 4.30's. I repeated the test a couple times to verify. How do you know you have the 3.91's? What rpms are you at traveling at 70 mph?
Re: 265/75's #487221 08/11/04 01:50 AM
265/75's will fit
they are just like the 31/10.50 tire
Re: 265/75's #487222 08/11/04 02:02 AM
Sorry, I should have specified 265/75-16's. They are about 1 inch taller than 31x10.5-15's.
Re: 265/75's #487223 08/11/04 02:22 AM
ah ok
so it would be a 32 tall
i have heard on the new tacomas that you can use a 32/11.50 with minimal rubbing
Re: 265/75's #487224 08/11/04 03:13 AM
Stock02 Offline
I spent many hours researching this same thing.
I'm runnin 265/75/16s on my 2.7l and full stock suspension.
I have NO problems with rubbing and I just got done wheeling hard at Paragon 2 weeks ago.
Power loss is minimal with a manual tranny.
02 Tacoma Xcb 4x4, runnin 32"s, 2.5" Daystar spacers, 1.5" Downey HD shackles, AOR sliders, SkidRow Tcase skid, 20# CO2 setup
Re: 265/75's [Re: Stock02] #487225 08/11/04 03:45 AM
Hey thanks Stock thats just what I was looking for. By chance to you know your gear ratio?
Re: 265/75's #487226 08/11/04 02:05 PM
little_joe Offline
Former Admin
My window sticker states 3.91 gears.
Hmmm, at 70 I am turning around 2700 rpm.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6259 MB (Peak: 0.7273 MB) Data Comp: Off Server Time: 2026-06-04 17:27:29 UTC
