Surging Ide :( #488695 08/13/04 11:19 PM
kmat123 Offline OP
I have a '94 Toyota Pickup 22RE 4x4. Lately I have noticed that ocassionally when idling at stop lights in 1st gear w/ the clutch in, my idle surges between 750 and 1250 rpms. When I put my parking brake on and put it in neutral the idle returns to normal (approx 750 rpms). Although this only happens a few times a week it is getting rather annoying. Anyone have any idea what might be causing this?
P.S. I changed the timing belt and adjusted the valves approx. 8K miles ago and just cleaned my K&N.
Re: Surging Ide :( [Re: kmat123] #488696 08/13/04 11:23 PM
Staceman Offline
Low coolant/water. Add some. That's the usual fix. Good luck.
Re: Surging Ide :( [Re: Staceman] #488697 08/13/04 11:29 PM
mainer Offline
your idle could be set to high also...
with the idle to high and you touch the breaks it cuts the fuel from engine. so it surges.
this is designed so when u are driving and touch the breaks with it in gear, it cuts the fuel down to idle amount to save fuel.
00 tacoma 4x4 ex-cab stock 193,000 and counting
85 long bed pickup 4x4 frame off restoration. rear lock rite 31's 268,000 miles
51 cj3a stock everything orginal 2500 original miles
Re: Surging Ide :( [Re: mainer] #488698 08/13/04 11:51 PM
Esquire812 Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> on both replies
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Surging Ide :( [Re: mainer] #488699 08/13/04 11:56 PM
4Crawler Offline
Not really a fuel saving item, its more safety or braking effectiveness. Assuming you are off idle (that is the engine is above about 1000 RPM) the ECU sees the brakes go on and assumes you want to stop. Why pump gas into the engine making power while you are trying to come to a stop.
And yes, turn down the idle speed if it is too high. I can exactly duplicate this problem on my 22RE if I bump the idle speed up over about 1050 RPM, at that point the idle surges with brake application. Turn the idle speed down and it idles normally.
Re: Surging Ide :( [Re: mainer] #488700 08/19/04 04:20 AM
kmat123 Offline OP
Thanks guys! It ended up just being low coolant. Sometimes the simplest solutions are the right ones! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Surging Ide :( [Re: kmat123] #488701 10/28/04 11:59 PM
Mine (95 4runner 3.0 w/ 180K) just started doing this and a couple other odd things.
Sometimes the idle surges, other times it just stays pretty high (2500rpm). When I hit the gas after coasting it sorta gives out or misses for a second before responding. It kinda acts like I've got bad gas. However, the engine is very loud--the belts sound like they need dressing or something.
It just started doing this yesterday. It didn't do it just after starting up, but after about 10minutes in town. Then it went away.
I'm going to have to check out the coolant issue. Anything else that it could be?
Re: Surging Ide :( --where is my coolant going? [Re: Staceman] #488702 10/31/04 01:07 AM
Surging idle problem diagnosed as low coolant. That checked out to be correct. Added more coolant, its gone. What are the most probable places to look for a leak, and what is the best way to do it? I've got a skid plate, so I think that's going to make hunting down a leak easy.
Thanks in advance for all the suggestions.
Re: Surging Ide :( --where is my coolant going? #488703 10/31/04 04:27 PM
mnwolftrack Offline
I wrote up some information on a page on my website about the bizzare idle:
www.geocities.com/toyotashawn/bizzareidle.html
Low coolant or high idle seem to be the most common causes. I think low coolant causes the problem becuase the temp sensor is up high and isn't bathed in coolant so the engine computer can't decide if it should be at cold high idle or warm low (normal) idle. The idle RPM problem happens for what the others have said, a fuel cut-off point that shuts the injectors off when decelerating.
Re: Surging Ide :( --where is my coolant going? [Re: mnwolftrack] #488704 10/31/04 06:09 PM
Surging idle at a stop sign can also be caused by a bad Master Cylinder, when you mash the brakes if the Master Cylinder (Booster) is bad it'll create a vacuum leak and make the truck start idleing funny. This happened on my 88' Toyota PU. Once i fixed the Master Cylinder everything was fine again.
Good luck
PHP: 7.4.33 Page Time: 1.576s Queries: 15 (0.007s) Memory: 0.6295 MB (Peak: 0.7375 MB) Data Comp: Off Server Time: 2026-11-16 08:51:19 UTC
