Re: Rear window not working on 98' Runner [Re: Hugh] #489449 12/12/04 08:49 AM
i have a 98 runner and out of the blue the rear window just stopped working. I tried the key but did not know of a 5 second delay so I will try that to see if the window is getting power. I was thinking maybe a fuse. I have only owned the 4runner for just two months so I am still learning this rig. Has anyone figgured out there problem yet?
Problem solved: Rear window not working on 98' Runner #489450 12/21/04 12:40 AM
Hugh Offline OP
Ok, given enough time, I was able to figure this out on my own. Aside from thinking that I can just go without a working rear window (4 months already), I applied knowledge that has worked in other areas of electronics <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Get yourself a few Q-tips and some dielectric grease. Remove the (center console) rear window switch and clean the contacts with a dry Q-tip. Now apply a very thin film of dielectric grease with another clean Q-tip. Put the switch and wiring back together, turn on the ignition key and <img src="/forums/images/graemlins/cheers.gif" alt="" /> Works great! As an added bonus, the key in the rear door also operates the rear window now - <img src="/forums/images/graemlins/mrt.gif" alt="" />
If this doesn't work, then check the continuity of the switch and keep troubleshooting.
--Hugh
Re: Problem solved: Rear window not working on 98' Runner [Re: Hugh] #489451 12/23/04 03:53 AM
Also, first always check that the rear wiper is properly seated on its perch. That will override rear window operation.
Get yourself a few Q-tips and some dielectric grease. Remove the (center console) rear window switch and clean the contacts with a dry Q-tip. Now apply a very thin film of dielectric grease with another clean Q-tip. Put the switch and wiring back together, turn on the ignition key and <img src="/forums/images/graemlins/cheers.gif" alt="" /> Works great! <img src="/forums/images/graemlins/mrt.gif" alt="" />
--Hugh
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5977 MB (Peak: 0.6528 MB) Data Comp: Off Server Time: 2026-11-15 15:26:53 UTC
