4runner lift kit #490369 08/17/04 09:54 PM
I am looking for a reasonably priced, lift kit for my 92 4runner automatic. I am looking for a 4 inch suspension lift. I am looking to fit 33" on it. Also I was wondering if I should keep my stock aluminum wheels or go with a wider set with a bead lock. <img src="/forums/images/graemlins/confused.gif" alt="" /> [color:"red"] [/color]
Re: 4runner lift kit #490370 08/17/04 10:28 PM
Mojo_Risin Offline
You can start reading here.
http://www.4x4wire.com/toyota/4Runner/tech/suspension/
Not sure if that helps or not.
Re: 4runner lift kit [Re: Mojo_Risin] #490371 08/17/04 10:38 PM
I have read all of that. It mainly points out the saggin back end on the 4runners
Re: 4runner lift kit #490372 08/18/04 02:32 AM
larsdennert Offline
Two options would be: a Trailmaster or Procomp 4" lift; or a 2" body lift from Roger Brown and Frank's balljoint spacer lift along with a 2" rear spacer or longer spring.
Re: 4runner lift kit [Re: larsdennert] #490373 08/18/04 09:21 PM
do you have any more info on the ball joint spacer lift?
PHP: 7.4.33 Page Time: 2.264s Queries: 15 (0.003s) Memory: 0.5969 MB (Peak: 0.6606 MB) Data Comp: Off Server Time: 2026-05-26 00:05:06 UTC
