Re: Camper shell & crawling [Re: Scott Broam] #490384 08/18/04 03:07 PM
Chris V Offline
Reusable seal? Where'd you get that? All I've seen is this cheap foam tape - but replacing it three times cost about as much as your $45 seal...
I got the reusable seal at the place where I bought the shell. I think any place that sells shells will have them. The standard seals are supposed to be replaced every time you take the shell off. These are good for a lot longer than that.
1996 T100 SR5, 4" Procomp Stage2,
33x12.5x15 tires
http://members.cardomain.com/chris_t100
Re: Camper shell & crawling [Re: Chris V] #490385 08/18/04 06:17 PM
Kookadala Offline OP
Great, thanks for all the thoughts. Chris, too bad you have a cab high or I would buy it from you. I definately need the extra head room so I am looking for an extended height version. Hard to find any used ones, any other truck models fit the T?
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: Camper shell & crawling [Re: Kookadala] #490386 08/19/04 12:10 PM
A
airrikk17 Offline
nope t , fits t only , closest ones arethe dakota , which is about 1 inch too sohrt , and the tundra , but the tundra has a differnt front shape .
airrikk17
'07 toyota fj crusier, with a bunch of goodies
84' jeep cj-7 , current offroad only project
Re: Camper shell & crawling [Re: airrikk17] #490387 08/19/04 02:44 PM
Scott Broam Offline
I measured a shell for a Chevy short bed (90 something model - not the latest body style) that was within a half inch in each dimension. Not sure if it would have worked, but it would have been close. It was sold when I came back... A dealer told me that they were selling the same shell for Ts and Tundras - might not be a perfect fit, but workable. Depends on your tolerances...
96 T100 Titan Xcab V6 2WD,Powertrax No-Slip Diff, buckets, mini-mods...
http://picasaweb.google.com/scott.broam/TruckProjects#
Re: Camper shell & crawling [Re: hummer_1] #490388 08/19/04 03:02 PM
JohnF Offline
The bolts I used hook under the inside edge of the bed, and go up through the base of the shell. I looked for them on the web but couldn't find them (mine are in storage, or I'd take a quick photo). They look sorta like this...
Re: Camper shell & crawling [Re: Scott Broam] #490389 08/19/04 05:48 PM
adam Offline
I have a toolbox from a 90s Chevy, and there's noticeable overhang. It's close enough to call good for a toolbox, but I don't know if it would be for the whole length of a cap.
~Adam
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6175 MB (Peak: 0.6876 MB) Data Comp: Off Server Time: 2026-06-07 09:30:20 UTC
