Re: Camper shell & crawling
[Re: Scott Broam]
#490384
08/18/04 03:07 PM
Reusable seal? Where'd you get that? All I've seen is this cheap foam tape - but replacing it three times cost about as much as your $45 seal... I got the reusable seal at the place where I bought the shell. I think any place that sells shells will have them. The standard seals are supposed to be replaced every time you take the shell off. These are good for a lot longer than that.
[Re: Chris V]
#490385
08/18/04 06:17 PM
Great, thanks for all the thoughts. Chris, too bad you have a cab high or I would buy it from you. I definately need the extra head room so I am looking for an extended height version. Hard to find any used ones, any other truck models fit the T?
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc. 99 F-350 4x4 superduty supercab turbodiesel longbed
[Re: Kookadala]
#490386
08/19/04 12:10 PM
nope t , fits t only , closest ones arethe dakota , which is about 1 inch too sohrt , and the tundra , but the tundra has a differnt front shape .
airrikk17
'07 toyota fj crusier, with a bunch of goodies 84' jeep cj-7 , current offroad only project
[Re: airrikk17]
#490387
08/19/04 02:44 PM
I measured a shell for a Chevy short bed (90 something model - not the latest body style) that was within a half inch in each dimension. Not sure if it would have worked, but it would have been close. It was sold when I came back... A dealer told me that they were selling the same shell for Ts and Tundras - might not be a perfect fit, but workable. Depends on your tolerances...
[Re: hummer_1]
#490388
08/19/04 03:02 PM
The bolts I used hook under the inside edge of the bed, and go up through the base of the shell. I looked for them on the web but couldn't find them (mine are in storage, or I'd take a quick photo). They look sorta like this... ![[Linked Image]](http://myweb.cableone.net/jlflanagan/autos/bolt.jpg)
[Re: Scott Broam]
#490389
08/19/04 05:48 PM
I have a toolbox from a 90s Chevy, and there's noticeable overhang. It's close enough to call good for a toolbox, but I don't know if it would be for the whole length of a cap.
~Adam  96 T100: D44, lockers and stuff
