Remove fixed canopy glass on 1st gen 4runner ? #490398 08/17/04 10:22 PM
W
whitetoy Offline OP
Any tricks to this ?
There are 7 little bolt/nuts to remove on the
inside. There is a little pry slot on the outside.
When I pry with a screwdriveR, the glass moves out
a bit, but is being held up by ?????
What do I do then ? Seems to be nylon clips
that I can see behind the glass, when I pry.
What do I do then ?
TIA
Rick
1984 4Runner
Re: Remove fixed canopy glass on 1st gen 4runner ? [Re: whitetoy] #490399 08/18/04 04:28 AM
G
Greg_Canada Offline
Straight from my FSM:
1. Remove nuts and bolts
2. Using a knife, cut off the window glass seal.
Push out the lower edge of glass, then raise the glass to remove it.
89 4Runner
Re: Remove fixed canopy glass on 1st gen 4runner ? [Re: Greg_Canada] #490400 08/18/04 09:42 AM
Paul Elbisser Offline
Thats about it, just take it slow. The seal it FIP, like calking. Pry it up a little, and use the knife to cut away the best you can. I have removed one before, and I didn't break it. So it can't be that hard.
Paul Elbisser #3233
pastTLCAEastern Rep.
Pres Rice on the Rocks
www.riceontherocks.org
Re: Remove fixed canopy glass on 1st gen 4runner ? [Re: Paul Elbisser] #490401 08/18/04 01:57 PM
Adam F Offline
Do you need a new seal when putting in glass? Or can I use some sillicone gasket maker?
97 4R, stock, daily driver
Re: Remove fixed canopy glass on 1st gen 4runner ? [Re: Adam F] #490402 08/18/04 02:29 PM
DRTDEVL Offline
It is sealed with butyl tape. It comes in large rolls of about 50', and is commonly found in RV supply stores.
I picked up a 50' roll for my windows at Coast RV in Crystal River, Fl., for about $5. It was marketed under the name "Tacky Tape."
Re: Remove fixed canopy glass on 1st gen 4runner ? [Re: DRTDEVL] #490403 08/18/04 06:38 PM
G
Greg_Canada Offline
And if you break the window, i have a spare driver side <img src="/forums/images/graemlins/notooth.gif" alt="" />
89 4Runner
Re: Remove fixed canopy glass on 1st gen 4runner ? [Re: whitetoy] #490404 08/19/04 03:25 AM
Cholltero Offline
I use a hooked knife to slice completely around the inside of the window (first space in from the fiberglass) Once its cut all the way around you can apply pressure to push the window out of its hole. When you put it back in use 3M brand butyl window cord you can get at a auto-body supply. Its much stickier and stronger than the RV stuff . Plus it comes in different diameters (1/4" , 5/16", 3/8") I think I used the 5/16" when I did mine and each window takes about 7 feet if I remember correctly. Clean all surfaces w acetone for good adhesion .I think the tape and inside moulding are all thats holding it on. Good time to paint the exterior trim too. My 2 cents
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
Re: Remove fixed canopy glass on 1st gen 4runner ? [Re: Greg_Canada] #490405 08/19/04 03:39 AM
And I got the passenger side <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Paul Elbisser #3233
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6203 MB (Peak: 0.7188 MB) Data Comp: Off Server Time: 2026-06-21 02:08:58 UTC
