3.5 V6 #491236 08/19/04 05:39 PM
1991monterols Offline OP
How can i adjust the idle on my 2000 trooper.
Thanks Nate
1991 Montero LS 5sp with 32s on black 15x8, snorkle, roof rack, 9000lb milemarker, cb, 4 hella lights sold
1991 Montero RS Auto on 35s, 2in BL, hella lights, cb, roof rack blown headgasket
Re: 3.5 V6 [Re: 1991monterols] #491237 08/19/04 05:47 PM
O
OffRodEO Offline
you cant its fuel injected. If it has a high or low idle somthing it wrong. But if you want to fix the symptom, i think there is a screw on the throttle cable as it connects with the butterfly valve. It allows it to not retract all the way. I think lol
kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
Re: 3.5 V6 [Re: 1991monterols] #491238 08/19/04 08:22 PM
BigSwede Offline
The idle is computer controlled...if your idle is off then you probably have a vacuum leak...which on a 2000 Trooper is probably the intake manifold gasket, although there are many other possible leak locations.
Serenity now!
PHP: 7.4.33 Page Time: 2.431s Queries: 15 (0.004s) Memory: 0.5921 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-06-22 21:05:13 UTC
