Re: 87 Montero using yota gear
[Re: 85monteroS]
#492329
08/22/04 10:19 PM
like bob said. i also recomend 4.3 swap way more versital and as for drivetrain leave your mits. rear and put in toy front.all you need then is to swap the tcase with a full size chevy and your output is on the right side. LOVE THE TOP MINE IS THE SAME WAY A LITTLE CLEANER JOB BUT I LOVE YOURS TOO!!!!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Hey How about some pics of your rig??
[Re: LandRaider]
#492330
09/09/04 04:05 AM
front diff is now mocked in and the rear is swapped in, now for the fussy stuff like brake cables and hoses etc, then onto the eng/trans/tcase. but on the lighter side i have all the front end parts and rear diff for sale
#492331
09/10/04 04:30 AM
#492332
09/12/04 05:53 AM
the front spring hanger is Ford F250 hangers welded to a receiver hitch cut to yota spring width, the front springs are yota 2wd rears, i am going to shorten the overload retainer to limit the pinion tip at full spring extension, the rear diff was bolt in just have to plumb the rear brake hose, then devise a park brake cable. Hmm maybe so kinda t/case mounted unit?? any ideas?
#492333
09/13/04 01:10 AM
got the motor and trans out this afternoon, not much else cept plasma cut the engine mounts off.
#492334
09/13/04 02:38 AM
Did you just get a donor truck for the yota parts?
'87 Raider w/rebuilt 2.6 Weber 32/36
[Re: Jamez]
#492335
09/13/04 04:25 AM
ya i have a couple, the axles have 4.37 gears and are from a 80 4x4 and the engine,trans,t case are from an 84 4x4 with 5 spd
#492336
09/15/04 08:19 AM
got the engine, trans, t/ case in yesterday, got the motor mounts tacked in (yota and Monero share frame width at engine mount area) tried to get nore done but work gets in the way
#492337
09/15/04 02:25 PM
...tried to get nore done but work gets in the way You've gotten a hell of a lot done so far. Keep us posted. I've never really thought about a SAS as 1) I'm still newer to wheeling, and 2) I've generally had a Mitsu purist mind set. But the more you all are doing this... Keep up the good work guys!
[Re: MontyMcV]
#492338
09/16/04 06:20 AM
started the basic wiring, and got it to fire today, anyone have wiring schematic for the Mitsu alternator?
