fuel consumption montero '91 #493596 08/25/04 11:19 AM
hi, my montero is been killing my fuel tank since 3 months ago, besides at 2000 rpm it seems to lose power, can somebody tell me what could be the cause.
thanks, byron
Re: fuel consumption montero '91 #493597 08/25/04 06:16 PM
NHMonty Offline
can you give a little more info on your montero, engine size, mods, etc.
1990 RS 4door 3.0L V6. 2 inch body lift. 33x12.50/r15 BFG AT's, 3 Superswampers(1 on the way) CD Player, Superwinch Hubs
My pics http://community.webshots.com/user/nhmonty
Re: fuel consumption montero '91 [Re: NHMonty] #493598 08/26/04 04:12 AM
Sorry about the lack of info. The Montero is 3.0l, 6 cilynders, 1991.
Re: fuel consumption montero '91 #493599 08/26/04 04:44 PM
PHIL_ Offline
When was the last time you did scheduled maintenance, ie spark plugs, air filter, etc. And what are you getting in terms of MPG? What type tires/size are you running? Do you have a roof rack? What type of drivign do you do - highway, city, offroad? Standard or auto? How many miles on the truck? Original engine?
PHIL
Re: fuel consumption montero '91 [Re: PHIL_] #493600 08/27/04 05:27 AM
Last time was about 1 month ago, and spark plugs, distributor cap, air filter, cables (spark plugs), motor oil, etc, was changed. The car is making like 15 MPG <img src="/forums/images/graemlins/shocked.gif" alt="" />.
The tires are 33x12.50/r15.
No roof rack.
The driving is 50/50.
Automatic transmission.
128,422 miles on the truck.
Yes, the engine is the original.
Now, I begin to have another problem: when the engine is cold and started, the engine sounds like if there werw 150
smurffs banging pipes against it, the car hesitates, the rpm 1300, that is without drive it, once in the road it feels like if the emergency brake was pulled, it feels tired, does it has to do with the consumption.
I really apreciatte all the help you are giving me.
Regards.
BYron
Re: fuel consumption montero '91 #493601 08/28/04 02:46 AM
socalmonty Offline
What kind of mileage are you seeing per tank?
Sean - Orange County, CA
MAIL: seanwilliams78@gmail.com
1995 Montero SR - For exploring and getting away!
1994 Volvo 850 Turbo - 402hp and counting!
1966 VW Bug 2275cc - For stoplight drags!
Re: fuel consumption montero '91 [Re: socalmonty] #493602 08/28/04 05:07 AM
Usually it made 21-23 mpg, now is making the third.
Re: fuel consumption montero '91 #493603 08/28/04 05:24 AM
PHIL_ Offline
Are you correcting for the oversize tires? Remember that your speedo gear is made for 235-75s. 33s are quite a bit bigger, so your indicated speed/mileage will be out by 15% or so...
PHIL
Re: fuel consumption montero '91 [Re: PHIL_] #493604 08/28/04 10:04 AM
yes, it is corrected. But the MItsu has had the same tires before and after the change in the mileage. Does anybody knows if OS could make the change, I change the OS like 1 month ago, due to the ssame problem, but after the change the consumption increased.
Re: fuel consumption montero '91 #493605 08/28/04 04:46 PM
PHIL_ Offline
<img src="/forums/images/graemlins/confused.gif" alt="" /> I'm not following you here...
You still haven't mentioned what type of tires. And for that matter, what air pressure are you running. I realize this is not the "fix" you're looking for, but MPG is such a wide-open thing, and there are many factors which can contribute... If your mileage dropped to 2/3 of what it was, then it could indicate a problem, but it could also indicate a change in driving habits, terrain, equipment, etc.
But all things being equal, and assuming everything else checks as "normal" when was the last time, if ever, that you had your fuel system serviced, ie throttle body cleaned, injectors flushed, etc? This can affect gas mileage, but its typically a gradual decline, rather than a sudden drop...
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6307 MB (Peak: 0.7526 MB) Data Comp: Off Server Time: 2026-06-23 19:43:51 UTC
