As far as speed, Ramsey is 35.4 fpm and Warn is 38 fpm for basically the same winch just different name, not much of a difference. Pull wise the Ramsey has 138:1 when the Warn has 156:1. This is for the 9500lb winch's, i would also recommend you get atleast an 8000lb winch because eventually you'll use every bit of it. Also its nice to be reassured that your winch wont give out due to overloading its full capacity.
