Re: FSM Question [Re: ErikB] #494091 08/29/04 07:30 PM
surlynkid Offline
If you're going to spend the money, get the right manual instead of beating your head against the wall trying to figure out the little differences while working on your truck. Sounds like you made that decision already though. smile
and there are plenty of little differences in the T-100 over the years. i even found that my FSM could not keep up. it shows the ADD tank in the passenger wheel well, but it is in the driver's wheel well.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: FSM Question [Re: rmg] #494092 08/30/04 01:44 PM
rmg Offline OP
Thanks guys. I think I'm going to get a refund from the guy. I forgot about this website where I can get the correct information. http://techinfo.toyota.com
I downloaded the 1995 T100 FSM from the above site this weekend. I signed up for the $10 day subscription and spent about 2.5hrs downloading the FSM, Toyota Service Bulletins, and many other documents on the 95 T. I am now going through each document and labeling them by page number and description to make it easier to find thigs later.
The downside is that the manual will be on CD and not paper form unless I print it out (which would use a lot of paper and ink). Also, if you use the site, have a high speed internet connection. It makes it go quicker because you have to open each pdf and then save them.
Ryan
95 T100 2WD ExtCab
All Stock
Re: FSM Question [Re: rmg] #494093 08/31/04 12:42 AM
garym Offline
Just curious how big the total file size ended up to be.I have high speed at work but no CDRW. Might be able to off load it onto one of those USB sticks.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: FSM Question [Re: garym] #494094 08/31/04 03:43 PM
rmg Offline OP
If I remember correctly, it was less than 50MB. I'll let you know if it is more.
Ryan
95 T100 2WD ExtCab
All Stock
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6095 MB (Peak: 0.6657 MB) Data Comp: Off Server Time: 2026-06-07 04:31:33 UTC
